Alternator help!! - JeepForum.com
post #1 of 2 Old 09-20-2007, 08:27 PM Thread Starter
ltdanyj
Alternator help!!
Put in a new engine. In the process, I converted my starting system from the '87(separate solenoid and starter), to a later model setup (starter and solenoid in one piece). Just starts and runs fine, but it's almost like the alternator isn't "waking up".... I have one wire left over from scrapping the old solenoid. It was a smaller wire that went to a 'front' post... next to the starter signal wire. could that be my problem?
Dan
"The Marines I have seen around the world have:
the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen.
Thank God for the United States Marine Corps!"
"Eleanor Roosevelt, First Lady of the United States, 1945
ltdanyj is offline
post #2 of 2 Old 09-20-2007, 09:04 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
you have three wires from your alternator
put the big one all by itself to the battery
the two wire connector:
put the really thin wire to a circuit that is energized whenever the engine is running
put the other wire (red) to the battery or the starter relay if you have one.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
Another Alternator???????????? 94stock YJ Wrangler Technical Forum 2 06-12-2009 02:31 AM
Need help with Hi Amp alternator loborojo338 YJ Wrangler Technical Forum 12 11-20-2007 01:05 PM
Alternator?? bama27 TJ Wrangler Technical Forum 3 10-22-2007 09:44 AM
Alternator slimjeep TJ Wrangler Technical Forum 1 03-23-2005 10:36 AM
Alternator????? 2000wrangler TJ Wrangler Technical Forum 7 01-13-2005 08:47 AM
