Alternator Electrical Hook ups - JeepForum.com
post #1 of 3 Old 09-04-2011, 09:09 PM Thread Starter
BamaCrawler
I am replacing the wiring in my Jeep Wrangler Laredao(4.2L) using a painless wiring kit. The wiring for the Ignition is giving me problems. Does anyone have experience with this? Should the exciter have power even when the key is off?
BamaCrawler is offline
post #2 of 3 Old 09-04-2011, 09:54 PM
Williabr78
I just replaced my wiring and ECU in a 1991 with the 4.0.
I know in your case the alternator is controlled by either an internal or external voltage regulator. In either case, the exciter should be powered from the ignition. In my case, the ECU controlled the alternator and I used an external voltage regulator from a 1988 dodge truck. Both control circuits were powered from the ignition.
Williabr78 is offline
post #3 of 3 Old 09-05-2011, 06:00 AM
JWELK
No. The exciter is the field, nothing more than a coil of wire. It will drain the battery if left powered. Don't know on this engine if the regulator is on the positive or negative side.
Do a search on this thread. I'm certain this question has been asked.
Regards,
Jim W
JWELK is offline
Alternator electrical connection nuts Dores37 YJ Wrangler Technical Forum 2 03-24-2011 12:01 PM
Electrical Problem...Alternator???? SupermanTJ TJ Wrangler Technical Forum 3 06-15-2009 11:51 AM
I have an alternator / electrical problem...Help! paultyler YJ Wrangler Technical Forum 27 02-23-2009 07:51 AM
Electrical, battery and/or alternator headaches… AR-Guy YJ Wrangler Technical Forum 4 10-20-2007 09:14 PM
electrical (alternator) question? Sia YJ Wrangler Technical Forum 3 07-30-2003 05:04 PM
