Alternator/Distributor Question. - JeepForum.com
post #1 of 8 Old 08-17-2011, 04:53 PM Thread Starter
SayBye
the wire that runs from my alternator runs into a black box looking thing that is bolted onto the side of the block. (91 4.0) it comes out of the other side of this box, and goes to the center pin on my distributer cap. what is this black box that? it looks like its bolted on with four bolts.
if whatever the box is, is bad, could have make my jeep not fire and fuel pump not prime? im getting a check engine light and the arrow light on the first key turn, and every one after that. thanks!
SayBye is offline
post #2 of 8 Old 08-17-2011, 04:58 PM Thread Starter
SayBye
so i did a little more research and from what i read its the ignition coil correct?
if the coil is bad, would that not allow me any fire, and not allow my fuel pump to prime?
SayBye is offline
post #3 of 8 Old 08-18-2011, 03:55 AM
Mark05059
if you have both conditions (no fuel and no fire) then I would sooner say that your crankshaft positon sensor (located on the transmission on the drivers side attached with 2 bolts) is your problem.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 8 Old 08-18-2011, 06:01 AM
bogleparsons
The ignition coil would prevent fire but not fuel
bogleparsons is offline
post #5 of 8 Old 08-18-2011, 06:16 AM
Que89YJ
LOL black box thing...... Saybye, you have enough post, put the info into your profile. You need to test fuel and spark. Do you hear ther fuel pump cycle when you turn on the key? Depress the valve on the fuel rail and see if fuel squirts out. Also check the codes:
http://www.jeepforum.com/wiki/index....k_Engine_Codes
Que89YJ is offline
post #6 of 8 Old 08-18-2011, 07:13 AM
UZI4U
Even if the fuel pump cycles, the pressure could be low and the pump will need changed. If you have no spark, your coil is dead. Your best bet would be to plug a scanner on it and see what you have from error codes and go from there.
UZI4U is offline
post #7 of 8 Old 08-18-2011, 07:29 AM
Que89YJ
You don't need a scanner. The post and link I gave will give you the codes. UZI4U is right about the pressure but the coil not giving spark can be a few things: basics first. Lets try and narrow it down
Que89YJ is offline
post #8 of 8 Old 08-18-2011, 09:08 AM
R3V413
http://www.youtube.com/watch?v=wM3uPEtWVvk
Btw, when you depress the schrader valve on your fuel rail, make sure your wearing some type of eye protection or just keep your head away from it. If you do have fuel pressure, it wont just squirt, but spray. Just a little FYI
JEEP=Just Empty Every Pocket
"Politics is war without bloodshed while war is politics with bloodshed."-Mao Zedong
"For Those Who Fought For It, Freedom Has A Flavor The Protected Will Never Know"-Unknown
00 TJ on 31x10.5x15's- DD
89 YJ-Under the Knife
R3V413 is offline
distributor cap question? 155mm YJ Wrangler Technical Forum 4 07-23-2010 08:58 PM
HEI Distributor Question TorqueWrench87 YJ Wrangler Technical Forum 9 12-03-2009 08:44 PM
Distributor question. virus YJ Wrangler Technical Forum 15 06-08-2009 04:48 PM
Distributor question jeepbub08 YJ Wrangler Technical Forum 2 04-23-2009 07:10 AM
HEI Distributor Question? jagarcia82 YJ Wrangler Technical Forum 3 04-20-2009 05:14 PM
