Almost there, just need a little help. - JeepForum.com
post #1 of 11 Old 03-20-2013, 12:19 PM Thread Starter
Relicmoto
So, my axle is in, sounds good, and I have an appointment next week for a windshield replacement. The only issues now, that will prevent my yj from passing inspection are electrical. The horn system doesn't work. The horn itself works when you jump wires to it. But no go on the horn button. Also, the marker light on the front driver fender doesn't work. I already tested the bulb and checked for voltage with a multimeter and nothing. Can these 2 problems be related? It appears that the circuits for both items share a wire loom. Where's a good place to start searching for a solution, besides jeepforum. Any help will be greatly appreciated and this community has no idea how much trouble it's saved me since I first got into jeeping.
Relicmoto is offline
post #2 of 11 Old 03-20-2013, 01:12 PM
soonermatt
Yes. Check the ground that is right there. I think they both have a ground which is by your air breather (where the horn is). I think it might go to a bolt under neath the horn or onto a bolt close to the radiator by the vent for the front axle. Get in there and figure it out! You got this!
soonermatt is offline
post #3 of 11 Old 03-20-2013, 01:23 PM
Que89YJ
Here is a link to download the FSM so you can follow the wiring diagram:
http://www.jeepforum.com/forum/f12/1...start-1414928/
Little to no chance of them being related. The running light can be jumpered across from the the other running light to get you past the inspection. If you want to trouble shoot the running lights more.
The horn is pretty easy. In the FSM look at the ignition switch. You will find a violet wire that powers the horn with the ignition on through a relay right above the fuse panel. What you need to do it on that relay check power on the violet wire with the ignition on. If you have power then ground the orange wire at the relay with a short jumper wire. This will activate the relay and sound the horn if the system is good. That tells you the problem is between the column and the relay. Post back what happens when you do this.
Que89YJ is offline
post #4 of 11 Old 03-20-2013, 07:45 PM
ROWA
ROWA's Avatar
I had a problem with the front turn-signal, it ended up being the electrical bulkhead on the fire wall. Remove the bolt in the center and unplug it, using either brake clean or electrical contact cleaner clean both sides of the plugs and contacts (use rag to collect runoff) , you might have to use a wire brush to clean corrosion. Before reconnecting use a liberal amount of Dielectric grease on both sides and after inserting pop the back of the plug to seat it, don't forget the center bolt.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #5 of 11 Old 03-20-2013, 08:04 PM
Que89YJ
That dielectric grease should be spring maintenance on all the yj connectors for everyone.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #6 of 11 Old 04-07-2013, 05:12 PM Thread Starter
Relicmoto
So, I finally got around to messing with this. I fixed the marker light on the fender flair. It's working as it should. I had to replace the socket. Now my right front turn signal is giving me problems. I replaced both of the little silver cans under the dash, idk the name for them. My turn signal indicators aren't working on the dash either. The other 3 corners work fine, it's just the passenger side front that's an issue now. Thanks guys for the suggestions.
post #7 of 11 Old 04-07-2013, 05:35 PM
Que89YJ
Does it come on at all? Can you hear the flasher relay click when you turn it on?
Fault codes:
No Start:
Que89YJ is offline
post #8 of 11 Old 04-07-2013, 09:24 PM Thread Starter
Relicmoto
The dimmer filament works as it should when the headlights are on, as does the light on the fender. The brighter filament does not flash when the turn signal is on, nor does the fender light. The rear signal flashes at the proper rate on that same side. There is clicking when it is on.
post #9 of 11 Old 04-08-2013, 08:30 AM
Que89YJ
Easy then, you flasher system is working ok. You need to use a test light/meter to see what you have on the wire at the bulb socket.
Que89YJ is offline
post #10 of 11 Old 04-09-2013, 05:13 AM Thread Starter
Relicmoto
I jumped power to the line from the battery to the socket in different spots tracing the wire back. Stripped then painted with plastidip. Traced it all the way back to the bulkhead harness. It's all good under the hood. Just need to fight the bowl of spaghetti under the dash left by the PO.
post #11 of 11 Old 04-18-2013, 10:59 AM Thread Starter
Relicmoto
Ok, I'd like to thank everyone who contributed to this thread. After using all of your suggestions I now have no electrical problems. Knock on wood.
