Quantcast Almost impossible starting, once it does, runs fine? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Almost impossible starting, once it does, runs fine?
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGSALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30
Old 04-05-2006, 10:10 PM   #1
psycho253125
'89 with the carbed 6. Carb was rebuilt about 2 yrs./30,000 miles ago. Last saturday it was fine. Sunday morning it was impossible to start. Seemed like the choke was stuck. Fuel flow is fine, and after about 10 min. of cranking, it runs like it was flooded for about a minute, then it's absolutely fine. No stalling, hesitation, nothing. It also doesn't matter if the motor's hot or cold, it's really hard starting. Any ideas would be a help.
psycho253125 is offline   Reply With Quote
Old 04-05-2006, 11:57 PM   #2
Leroux
My brother just had the same problem with hard starts. Then one day it just ended up not starting at all. After a week of troubleshooting we found out it skipped a tooth on the timing chain. Replaced that and it runs and starts like a champ.
'93 YJ 4.0 i6, 8.8ls, D30 w/Aussie & Alloy USA shafts/disco removed, 4.56's, 3.5" Fabtech (gathering parts for SOA), 5/8 MORE Boomerangs, SYE, Coast Driveshaft, m8000, "Accordion style" Header w/full exhaust, 33" Siped BFG MT's, TJ Flares.
Leroux is offline   Reply With Quote
Old 04-06-2006, 12:36 AM   #3
Petrucci
sounds like the choke, I had a simular problem with my mustang, installed a manual choke and now works fine
Petrucci is offline   Reply With Quote
Old 04-06-2006, 07:20 AM   #4
psycho253125
Checked out the choke, does everything it's supposed to. Plugs and wires, etc. are good. I started there thinking it was a fowled plug
Old 04-06-2006, 07:41 AM   #5
vadslram
I had a similar problem w/ '66 mustang. The problem ended up electrical, when I was cranking it it didn't have the "right"? juice for ignition. I had the ah-ha moment when I ran out of juice to crank and last ditch pushed it. Started right up???????
The ingnition switch was funky, I replaced it and it started up every time. May not be your prob but I thought I'd share.
vadslram is offline   Reply With Quote
Old 04-09-2006, 09:07 PM   #6
psycho253125
Turned out to be the choke. I decided to order a new intake that can hold a 4 barrel edelbrock, since i have one laying around. thanks for the help.
Old 04-10-2006, 06:51 AM   #7
pyro9862
I had a 4 barrel holley on mine 380cfm. It ran horribly and got 6-7MPG I replaced it with an MC2100 within 2 weeks of getting the thing. I'd recommend against the four barrel especially if it's larger than 350cfm.
pyro9862 is offline   Reply With Quote
Glock Forum
