#1 | |
Almost finished with my SOA
Finally got down to business last night. Got almost everything down with the SOA I've been planning for the past 7 months. Things that are left are measure for and order rear driveshaft and shocks, replace all hard brake lines, replace front driveshaft u-joints, install traction bar, remove transfer case drop, and install longer center pins on front leaf springs so we can install 1/2" lift blocks to stop the tie rod from hitting the spring. A bunch of little things to get done over the next week or so but the hard work is done. And time for pictures
Before ![]() ![]() ![]() After ![]() ![]() ![]() ![]() Custom powder coated diff covers ![]()
#2 | |
jeepsurf endorses this post. Most of the time Admin, nightcrew.org 1990 2.5 YJ / 1997 2.5 TJ USAF VET |
#3 |
Thank you!
#4 |
Senior Web Wheeler
Looks VERY nice.
Which steering setup did you go with? It looks like heims which makes me think it's the MORE kit. I had clearance issues with that kit so if that is what you have make sure your 1/2" block doesn't put the springs into the drag link. I think I ended up using a 2* shim which angled it back for a little more caster and helped with the spacing.
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter. 98 XJ build thread |
#5 | |
#6 | |
Senior Web Wheeler
The other options would be to put the tierod under the knuckles and adjust the caster ... or.... I don't have any better pictures but I ended up mounting the drag link on top of the bracket. I filled in the bracket with a piece of tube and welded it in. I know, it makes it single shear, but it's already single shear on the pitman arm and you can always add a tab on top the bracket to make it double shear: ![]()
#7 |
Thanks for that picture and idea, I'll see how it goes after getting that block in and then figure out where to go from there
#8 | |
I'll be doing a SOA on my '91 soon, but I'm waiting on finding a Dana 44 F & R waggy donor Jeep to buy first. I did a SOA on my wife's '93 YJ, and I used the Rocky Road OTT high steer kit. I know I'll take flak for speaking nice about RR on here, and believe me, I sure had my share of their customer dis-service that is so well known! But, I did like the OTT high steer setup, and it has held up well, with no issues yet. Here's a pic of her's installed. http://img103.mytextgraphics.com/photolava/2007/05/08/dsc035411-46enb7xn0.jpg |
#9 |
The kit came with longer center pins but they are the wrong diameter for our springs. Once we get the right ones in I'll throw up a picture of the new clearances.
#10 | |
Senior Web Wheeler
You'll be very happy with those axles. Having real hubs and the ability to run true high steer arms and 1 ton TREs is awesome:
#11 |
Does anybody know an e-brake cable that would work for my passenger side? I've been searching but can't find what I read before. Maybe like an XJ passenger side?
#12 | |
Senior Web Wheeler
I think XJ cables are shorter b/c they come from the middle of the body ... then again they are longer wheelbase.
#13 |
I'll look into that LJ idea
#14 |
The LJ cable comes from the middle of the body as well. The parking brake is in the center console. It's a pretty short cable.
#15 | |
Senior Web Wheeler
Poo. Well, for what it's worth, I run two pass side cables on mine because my driverside was too short. I'd think most e-brake cables are going to be similar but it may be time to take a drive to a parts yard and do some inspecting.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
