Almost Embarrasing Question - Bracket for Reverse Sensor on AX-15 - JeepForum.com
post #1 of 4 Old 09-25-2010, 06:29 PM Thread Starter
IP076
Tried searching, can't seem to find it...and I'm almost embarrassed to admit I can't find it...the whole swap of putting in a rebuild AX15 has went really well...and now I cant seem to find the bolt the little bracket for the wiring for the reverse sensor attaches to on the pass. side. Anyone got a picture handy?
Thanks!
IP076 is offline
post #2 of 4 Old 09-26-2010, 05:25 AM
kloppk
Here you go.
kloppk is offline
post #3 of 4 Old 08-16-2011, 09:59 PM
02grandy
02grandy's Avatar
I have a 92 2.5l with a 5 speed manaul. one wire on the reverse sensor were toast right near the sensor so i was unable to repair them. dont think i can soder. ive been looking on line and havent found anything do you know any websites that have it for a good price. ant suggestions or advice is welcome thanks.
02grandy is offline
post #4 of 4 Old 08-16-2011, 10:14 PM
timatoe
timatoe's Avatar
You may get a better response with a new thread, but if you can't fix the wires I think your only option will be to replace the switch. You should be able to get a switch at a local parts house.
timatoe is online now
Reverse Light Sensor/Switch '05 armartel TJ Wrangler Technical Forum 4 08-06-2010 09:40 AM
Crankshaft position sensor and o2 sensor bracket help diy4x4 TJ Wrangler Technical Forum 0 03-02-2009 04:07 PM
Embarrasing! What did I buy?? Japex TJ Wrangler Technical Forum 12 05-30-2008 01:26 PM
Reverse Sensor or switch ThisguyhasADD TJ Wrangler Technical Forum 4 03-29-2008 09:50 PM
Reverse Light Sensor Removal....help needed Rynxprs YJ Wrangler Technical Forum 6 08-23-2004 07:31 AM
