Quantcast Alloy USA Billet Axle Seals - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Alloy USA Billet Axle Seals
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 04-29-2009, 03:24 PM   #1
iking87
I bought a set of these about 2 years ago from DC4WD and finally got a chance to install them so I installed the one of the drivers side with RTV and then go eat dinner. When I come back the RTV is dry so I insert the axle shaft and put the brakes on, jobs half done right? Not quite. I proceed to install the passenger's side the same way and when I go to insert the axles shaft in it the shaft doesn't fit because the inner diameter of the seal is too small. This being the case I take the seal out before the RTV has a chance to set. Now I don't know what to do. DC4WD is no longer in business and Alloy went bankrupt and is run by another company. When I ordered the seals I specifically said I had a 91 YJ which means I have the 3 piece axle. What to do what to do? Anyone had any experience with Alloy USA or this issue in general?
iking87 is offline   Reply With Quote
Old 04-29-2009, 03:31 PM   #2
fyrdriver
Those seals only work with the one pc TJ style axles. Either dont use the seal or change out the axle on that side and bypass the axle disconnect.
Firefighters Jeep Club
http://groups.jeepforum.com/Firefighters_Jeep_Club
fyrdriver is offline   Reply With Quote
Old 04-29-2009, 03:33 PM   #3
jeepster93
jeepster93's Avatar
I am almost positive that the add you bought them from said something to the effect:
"will not fit an axle with the vacuum disconnect"
Anyhow...Those seals will not fit the passenger side with a 2 piece axle...sorry.
jeepster93 is offline   Reply With Quote
Old 04-29-2009, 03:40 PM   #4
iking87
Guess it's time to get a TJ shaft and keep it clean. Thanks for the help
Old 04-29-2009, 05:42 PM   #5
timatoe
Jello Puddin'
timatoe's Avatar
Yep, that's what you've got to do. OR send them to me
Originally Posted by jbolty View Post
... never underestimate the idiocy of Nancy Pelosi...
timatoe is offline   Reply With Quote
Old 04-29-2009, 06:25 PM   #6
kloppk
Actually there were 91 YJ's built that did not have the axle disconnect.
The "KDX" version...
kloppk is offline   Reply With Quote
Glock Forum
