#1 | |
alloy usa axle seals
can i use them as actual axle seals? my inner is leaking and i dont feel like gettin in there and doing it, and i came across the alloy usa seals. just wondering if they will retain all fluid in the axle.
#2 |
just replace your inner seals...
lx015oɹd uǝpıun 'ɥɔuıʍ ql0009ɟɥ ؛ɹǝıɹɹɐɔ ǝɹıʇ pol 'sɹǝpuǝɟ ǝqnʇ pǝɹɐlɟ"5˙4ʇuʇ :˙ɔsıɯ ؛sɹǝpıls sʞɹoʍʞɔoɹɥs 'pıʞs ǝuıƃuǝ ɔıpǝɯdǝǝɾ 'pıʞs ɹoʇɐıpɐɹ s,ʎʇsnɹ 'ʞuɐʇsɐƃ puɐ xoq ƃuıɹǝǝʇs ʇɥƃıɹuǝƃ :spıʞs ؛pɐoɹɟɟo ɹoɟ sɹǝƃƃoq"53 'ʇǝǝɹʇs ɹoɟ s,ʇ/ɯdɯoɔoɹd"53 :sǝɹıʇ ؛lɯɯ"1 'lq"52˙1 'spq "2 :ʇɟıl ؛ɹǝʌoɔ uǝɯʞoɹ 'loods-ıuıɯ 'sǝʞɐɹq ɔsıp 'sʎollɐ ɥʇıʍ 44p ؛ɹǝʌoɔ ɹǝɥsnɹɔʞɔoɹ 'slɐǝs ǝlxɐ ɹǝʇno 'ɹǝʞɔol ǝıssnɐ 'sʎollɐ /ʍ 03p '6ı :ɾʇ,00 44p '03p '6ı :5ɾɔ,37 s,ʇ/ɐ ƃɟq"23 '44p '03p '8ʌ063 :5ɾɔ,47 The Swamp Things 4x4 Club Jeep Talk HomeGrown Offroad |
#3 |
Free clues & suggestions
I highly doubt that Ron would warranty them to retain fluids since they are designed to keep junk out & not in.
Call Ron directly & ask him. |
#4 |
Good question I have thought about doing the same swap from what I have read though the seals you mentioned were made for the TJs not YJs. Not sure if the shaft opening on the housing of the YJ are the same size as a TJ but if it is I don't see why it wouldn't work.
#5 | |
#6 |
would the seals work if u had usa alloy chromos on the yj?
Great Lake Jeep Thing My work http://www.jeepforum.com/forum/f22/sparkys-garage-thread-790873/ |
#7 |
I've got the one piece passenger side axle in mine and run the axle end seals. They work great keeping water and dirt out, but they WILL NOT replace a leaking oil seal.
88 Wrangler, Rebuilt I6, NV3550,Atlas 2,B&M Shifter,38/38 Weber, Skyjacker Lift & Nitro Shocks & Stabilizer, Black Diamond Discos, 35 " Regul MT's & Outlaw 2 Alum Wheels, 4.88 Gears, Dana 35 & Super 35 kit & Detroit Soft Locker, Dana 30 & Superior Axles & Detroit Soft Locker & No Disco, SRC Front & Rear Bumpers, SRC Side Armor, Warn XD 9000 I Winch & In Cab Controls, OR Fab Tire & Can Carrier, Rock Hard 4x4 Full Cage, Hood Rack & Hi Lift & AX, Outland Seats, KC & Silverstar. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
