To all of those who own UCF tc skidplates. - JeepForum.com
post #1 of 7 Old 05-23-2011, 10:49 PM Thread Starter
JohndKc
1987 YJ Wrangler
I bought my skid plate a couple of weeks ago and am finally getting it installed. I got the skidplate that is between super skinny and super fat. My question is about the transfer case skidplate mounting surface to the frame. In all of the pictures that i see the plate sits flush to the frame. I have sleeves that come out of the frame that impede its final resting place. Did you just grind them down flat/till you could seat them in the holes of the skidplate?
http://www.jeepforum.com/forum/attac...1&d=1306208958
JohndKc is offline
post #2 of 7 Old 05-23-2011, 10:50 PM Thread Starter
JohndKc
1987 YJ Wrangler
EDIT: My stupidity at its finest.
JohndKc is offline
post #3 of 7 Old 05-24-2011, 03:50 AM
fratis
fratis's Avatar
yeah i noticed the same thing. was thinking about rewelding inserts in the frame flush. looks like if you simply grind it flush you will loose too much of the factory weld. im going to leave mine for now as ive got a ton of bigger issues.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #4 of 7 Old 05-24-2011, 08:03 AM
Doch80
I'm confused... what?
Doch80 is offline
post #5 of 7 Old 05-24-2011, 08:25 AM
jbolty
jbolty's Avatar
It's the outer part of the nutsert and is only about as thick as a washer. I would not worry about an extra 3/16 of clearance too much.
jbolty is offline
post #6 of 7 Old 05-24-2011, 07:53 PM Thread Starter
JohndKc
1987 YJ Wrangler
Can you explain to me in detail how you modified the transmission mount? I would really like to lower my transmission a little more. I had to hammer out the tub at the rear output to get the CV from contacting, but i have a nagging suspicion that with a little rough luck my drive shaft would come through the floor. I would really like to install this without a body lift.
JohndKc is offline
post #7 of 7 Old 05-25-2011, 01:13 AM
fratis
fratis's Avatar
i have the super flat with no BL. i think jbolty and i did a similar deal. i removed the rubber mount from the torque/ mounting plate. i cut off the mounting studs from the plate and welded my own on the same distance apart as the mounting holes in the skid. i used about 2" thick piece of rubber between the plate and the skid. the factory setup is a bit redundant having to bolt the plate to the rubber then bolt the rubber to the skid. this just simplifies the design. had to beat the tunnel for the very top of the trans. didnt have a problem with the cv. no MML at this time.
fratis is offline
Stock with skidplates? Vertisce JK Wrangler Technical Forum 3 08-30-2009 02:29 AM
Sahara Skidplates bsteeves86 JK Wrangler Technical Forum 14 06-03-2009 09:46 PM
Need help picking out Skidplates. Mike318_ YJ Wrangler Technical Forum 19 01-02-2009 12:29 AM
WTF is up with the stock skidplates?? franco802 TJ Wrangler Technical Forum 5 11-04-2003 12:07 AM
