All or nothing choke plate? - JeepForum.com
post #1 of 1 Old 10-12-2011, 05:24 AM Thread Starter
bluedaffy
Does the choke plate either lay flat when it's cold, and vertical when it's warm? Or does it set the choke angle on a gradient based on "how cold" it is. For example would it set the same closure if it were -20*F or 40*F?
I always check mine in the morning before starting to see what it looks like and it has never closed flat, it goes to somewhere between vertical and flat on these 40*F mornings.
Thanks for the insight
bluedaffy is offline
carb , choke , cold start , idle , plate
Can I convert a weber 32/36 electric choke to manual choke? jake42 YJ Wrangler Technical Forum 2 07-19-2011 05:14 PM
89 Choke plate Bravo181 YJ Wrangler Technical Forum 4 02-06-2010 05:55 PM
How do I get 90 degree choke plate? Stauffeneker YJ Wrangler Technical Forum 0 01-07-2009 04:26 AM
How far does your choke plate go? Stauffeneker YJ Wrangler Technical Forum 0 12-29-2008 02:13 PM
Weber 34 - choke plate won't open?? defmornahan YJ Wrangler Technical Forum 8 12-01-2008 09:05 PM
