All new stuff, won't start - JeepForum.com
post #1 of 16 Old 09-30-2013, 07:52 PM Thread Starter
skstobaugh
1987 YJ Wrangler
I have a problem that my YJ will not turn over the starter with the key. I have a new starter, new solenoid, new battery, new neutral safety switch and the solenoid just engages but that is all it does. I checked out the solenoid with a voltage/ohm meter and it passes all test. When I have the key turned on to start I get 12v to the starter side of solenoid and to the connection on the starter. When I use jumper cables from the battery straight to the starter it will engage the starter. I replaced the neutral safety switch and the old one acts like the spring inside is collapsed. I thought about the ignition switch but it is activating the solenoid. Is there anything else thru the ignition that would stop it from starting? HELP this is driving me nuts.
skstobaugh is offline
post #2 of 16 Old 10-01-2013, 04:48 AM
superj
your wires are correct on the solenoid?
ohhh, i just thought of something. if hte solenoid mounting tabs are not grounding properly, the solenoid won't work. clean the metal under the arms that hold the solenoid to the firewall and then try starting. that got me on my 87 for a bit till someone commented on it to me. i cleaned and painted my firewall solenoid area when i replaced mine and had a no start condition afterwards
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 16 Old 10-01-2013, 05:51 AM Thread Starter
skstobaugh
1987 YJ Wrangler
Everything is the same as when it was running as far as the wiring. I will double check the ground on firewall. I will run a ground wire to the mounting plate to be sure.
post #4 of 16 Old 10-01-2013, 06:31 AM
Rproject
1987 YJ Wrangler
If you have 12V on the back side of the solenoid and 12V at the starter, but it won't fire over unless you "jump" it, then I'd be on the ground wire. Your ignition switch is obviously closing its circuit to send voltage to the solenoid. The solenoid is allowing the voltage to pass to the starter. The hot side is getting to the starter, I'd be looking straight at the starter ground.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #5 of 16 Old 10-01-2013, 08:30 AM Thread Starter
skstobaugh
1987 YJ Wrangler
Rproject: You were right on the money. I hooked up a starter bolt ground wire to the frame and she fired right up. The thing I don't understand is the starter is bolted to the bell housing that is bolted to the motor that is grounded to the frame. And it was working before and all of a sudden it just quit. Anyways I guess it is what it is.
Thanks so much for your help.
post #6 of 16 Old 10-01-2013, 08:40 AM
Rproject
1987 YJ Wrangler
You're welcome. Corrosion between the starter and flywheel housing?
1996 White ZJ
Rproject is offline
post #7 of 16 Old 10-01-2013, 08:46 AM
Que89YJ
The bolts are zinc coated for corrosion resistance. They are high impeadance and not a good ground.
Que89YJ is offline
post #8 of 16 Old 10-01-2013, 10:36 AM Thread Starter
skstobaugh
1987 YJ Wrangler
Yeah. The grandson does go muddin' a lot. He is 17 and I (PawPaw) am his personal mechanic. So he thinks. Oh well at least it keeps him out of serious trouble.
Thanks again.
post #9 of 16 Old 10-01-2013, 10:40 AM
Rproject
1987 YJ Wrangler
I get some really nasty starter noise after a good mud outing. A good hose down of the starter usually cures it. A couple tikes I've had to pull the starter to clean the excess trail mud out of it.
1996 White ZJ
Rproject is offline
post #10 of 16 Old 10-01-2013, 04:12 PM Thread Starter
skstobaugh
1987 YJ Wrangler
I found the root cause. The factory braided ground cable from the firewall to the back of the motor was broke therefore no ground from the body to the motor. Now it makes sense.
post #11 of 16 Old 10-01-2013, 04:27 PM
Que89YJ
That ground does not carry any current. It is for ignition noise. If disconnecting that ground makes any difference then your battery ground or engine ground are bad. That ground will fail if it is used to carry that amount of current.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #12 of 16 Old 10-01-2013, 06:00 PM
superj
Maybe that ground burned through when the engine or starter ground failed or was disconnected?
superj is offline
post #13 of 16 Old 10-02-2013, 04:41 AM
Que89YJ
Disconnect the strap and see if it's repeatable.
Fault codes:
No Start:
Que89YJ is offline
post #14 of 16 Old 10-02-2013, 09:41 AM Thread Starter
skstobaugh
1987 YJ Wrangler
The strap is broken in half. I will disconnect the new ground I put on to the frame and connect it to the firewall and see if it starts just as an experiment to se if that was it. It almost has to be it because that is the only thing that changed. One minute it was starting and the next turn of the key it would not start, just click of the solenoid. I will let you guys know what happens. It's either that or it's the fact the starter all of the sudden somehow became ungrounded from the bell housing. I'm betting on the ground strap, but we will see. As soon as I can get my Grandson to stay still long enough I will try it and let you guys know.
Thanks again to all for your help.
post #15 of 16 Old 10-02-2013, 10:43 AM
Rproject
1987 YJ Wrangler
As soon as I can get my Grandson to stay still long enough ........
Pull the ignition wire from the starter solenoid in the middle of the night. That'll keep his happy feet on the ground for a few days.
1996 White ZJ
Rproject is offline
