all gauges quit working. - JeepForum.com
post #1 of 13 Old 07-07-2012, 03:17 PM Thread Starter
rawlston
I was just working on my radio and all of my gauges and dash lights just quit working. Does anyone know what I might have done or how to fix it? I've already checked all of the.fuses.
Just
Empty
Every
Pocket
"Guns kill people like spoons make Rosie O'Donnell fat."
rawlston is offline
post #2 of 13 Old 07-07-2012, 03:19 PM
liftedyj91
Try moving your light dimmer switch. Mine is finicky if its not just right lights don't work
check out
to see my build!
liftedyj91 is offline
post #3 of 13 Old 07-07-2012, 03:25 PM
MaddBones702
Is the assc fuse loose? I a have to bend it a Little to make it work
Who knew where this would go?
MaddBones702 is offline
post #4 of 13 Old 07-07-2012, 03:35 PM Thread Starter
rawlston
Not the dash lights sorry its the brake light, check engine light, etc. The ones right behind the steering wheel. I'm more concerned that all of my gauges tach, Speedo, battery, temp, fuel, just quit working.
No the fuse isn't loose. I ecen tried bending it like you said but still nothing.
Just
Empty
Every
Pocket
rawlston is offline
post #5 of 13 Old 07-07-2012, 03:39 PM
MaddBones702
What did you do to the radio?
post #6 of 13 Old 07-07-2012, 03:53 PM Thread Starter
rawlston
I have and aftermarket radio and I wouldn't turn on so I took it out but as soon as I got it out it started working so I just put it back in and when I was resetting the clock I noticed the the gauges weren't working
Just
Empty
Every
Pocket
rawlston is offline
post #7 of 13 Old 07-07-2012, 04:20 PM
dancytron
dancytron is online now
post #8 of 13 Old 07-07-2012, 04:40 PM Thread Starter
rawlston
Originally Posted by dancytron
Thanks for that. I'll try cleaning it but I'm almost positive its in the wiring.
Just
Empty
Every
Pocket
rawlston is offline
post #9 of 13 Old 07-07-2012, 07:10 PM
MaddBones702
Can you redo what ever you did at the beginning?
post #10 of 13 Old 07-07-2012, 07:22 PM Thread Starter
rawlston
I've tried backtracking. I checked all of the plugs and wires under the the dash and along the firewall and they seem fine. I don't want to but I may just have to take it somwhere. I just didn't want to spend $100 or more dollars just for someone to look at it.
Just
Empty
Every
Pocket
rawlston is offline
post #11 of 13 Old 07-07-2012, 07:57 PM Thread Starter
rawlston
Hey everyone I was reading around some other threads and found one where a guy changed the fuse even though it didn't look bad and it worked. I didn't the same thing and everything is back to normal plus I fixed the temperature gauge when i had the cluster out that wasn't working even before...apparently the wire had come out of the plug.
All I can think of is thay I crossed a wire when I had the radio out and blew the fuse (which still doeant look bad) oh well.
Thanks for all the help and advice.
Just
Empty
Every
Pocket
rawlston is offline
post #12 of 13 Old 07-08-2012, 06:42 AM
alc60560
This is a fun one.
The most common thing to blow that fuse is the back-up light switch connector located next to the cat. Check there first make sure it is not melted then change the fuse. We found this the hard way. They also have the scematic in the haynes manual. Good luck
alc60560 is offline
post #13 of 13 Old 07-08-2012, 07:39 AM
moonpie312
Funny story when I bought my jeep I got the guy to knock off 500 bucks because the gauges were working one minute and not the next. well after long hours of the entire dash out and entire fuse box cluster hanging checking everything with volt meters and test lights.........
The fuse was corroded on the output side of the fuse, hence when you checked it, it checked good because it was getting power in and out just not connecting to the wire..
so.. a few cents fuse and a few hours and it saved me 500 bucks off the original price
moonpie312 is offline
