All about shackles - Page 6 - JeepForum.com
post #76 of 99 Old 04-03-2009, 09:05 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by Mean Max View Post
Front track bar still on? That is usually the thing that screws up most folks.
Remove the track bar (if you still have it on) and then install the new shackles. Then deposit the track bar in Joe Dillard's favorite blue garbage can.
Max
How dare you recommend that!
I do agree, the tracbar can cause issues when trying to install the leafs.
There, fixed it for you!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #77 of 99 Old 04-03-2009, 09:05 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by rob1208lv View Post
THATS where mine is pulling now, i need it to go the other way.
Ditch the bar, permanently.
Max
Mean Max is offline
post #78 of 99 Old 04-03-2009, 09:38 PM
rob1208lv
Max
I'll try again next week and report ..
rob1208lv is offline
post #79 of 99 Old 04-06-2009, 09:39 AM
rob1208lv
I got the front ones on easy after taking the tracbar off.. Now I am trying to get the rear off these ones suck..
post #80 of 99 Old 04-06-2009, 10:01 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
WOOPS, no what I ment was the track bar was pulling my suspension 1/2" to the drivers side. I removed the track bar and it went back to center.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #81 of 99 Old 04-06-2009, 12:12 PM
rob1208lv
yes I got the front on no problem after I took the tracbar off,
now I can't get the back ones on. I have no problem taking the bolts out (didnt even have to cut them) my problem is I can't get the rear springs to budge meaning they just spring back into the frame.. what can I do to relieve the pressure? I have the jeep on a lift up in the air on all 4's but the rear springs just slam into the rear frame..
post #82 of 99 Old 04-06-2009, 02:30 PM
rob1208lv
Never mind I got it the old lift between the frame and the spring trick.. thanks for everyones help..
post #83 of 99 Old 09-07-2009, 12:20 PM
Rohdawg
Yes I am reviving an old, but very informative thread.
So if I read through all this correctly I will be alright if I add shackles that net me 3/4 or 1 inch of lift without messing everything else up?
I'm just looking for a little more clearance on my 89 YJ with a BRAND NEW RC 2 1/2 lift.
I bought this Jeep a year ago completely stock and everything on it was original. Upgrading as I can afford it.
89 YJ, 4.2L I6 automatic, 2.5" RC lift, 1" RC Boomerang Shackles, 33x12.5 Trxus STS, Trac bars are in the blue trash can
Rohdawg is offline
post #84 of 99 Old 09-10-2009, 11:32 PM
skeeterbeater
you said you have made shackles. can you do a wright up on it. i currently am broke and jobless so i feel if i can make it i will do it.
its not the biggest baddest rig on the trail, but i beat the hell out of it and have a good time.
skeeterbeater is offline
post #85 of 99 Old 09-12-2009, 10:00 AM
Echo5Sierra
This thread saved me some time. Thanks.
Echo5Sierra is offline
post #86 of 99 Old 09-12-2009, 10:09 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Good article I think it should be a Sticky
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #87 of 99 Old 09-12-2009, 04:22 PM
GromMudder757
yo i love this thread it helps out alot
GromMudder757 is offline
post #88 of 99 Old 11-25-2009, 11:27 AM
Wac
Brandon,
You helped me on this thread a few years ago... another question... Here is a picture of my current shackles up front, 6" or so, bolt-to-bolt centerline from farthest two bolts. The problem I have is that in the back I have boomarang shackles... but in the front, this is what 4wd.com sent me. To me, they look almost vertical, and there isn't much "give" in the front dringing over bumps. Would a boomarang in the front help?? Any advice on what to buy?? Will a boomarang provide a better articulation and ride??
Thanks a bunch!!
Wac
Wac is offline
post #89 of 99 Old 11-25-2009, 11:37 AM
bgredjeep
1987 YJ Wrangler
Originally Posted by Wac View Post
Brandon,
Thanks a bunch!!
Wac
[IMG]C:\Documents and Settings\Wacker Family\My Documents\My Pictures\Ebay Photos & Videos\SDC13386[/IMG]
You can't post a pic from your hard drive for other users to view on the internet. You'll need to post the pic on a hosting site then link from that location.
Besides that, the shape of your shackle won't have any effect on your shackle angle. This is related to your spring length. It is possible that you tightened the shackles too tight when installing them so the springs are not able to freely settle or move when you hit a bump. If you tightened the bolts very tight during the install, just back them off a little. Personally I just add some threadlock and tighten until there is no play between the shackle and the bushings.
Its also possible that your lift springs are just not as long at rest as the stock YJ springs. Nothing you can really do about that other than most the spring hanger a little closer to the shackle end of the spring (cut the stock hanger off and weld it back on closer to the other end of the spring).
bgredjeep is offline
post #90 of 99 Old 11-25-2009, 11:54 AM
Wac
Thanks! Take a look at the pic I posted... I keep my bolts @ about 25'lbs of torque w/ thread lock... so pretty loose as well. Just wondering if the springs would move easier or absorb more of the shock rather then transfering to the cab, with a boomarang set up... since the upward pressure of the shackle I have would be almost perfectly vertical, thus creating resistance and transferring the bump shock to the frame etc???
My thoughts were similar to:
In order to bend a piece of metal rod that is straight, lots of force is needed when pushing from each end... if the metal rod is pre-bent a little, then the force needed when pushing from each end would be considerably less.... would this analogy work describing a boomarang vs. straight shackle like mine????
Wac is offline
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 02:35 PM
To add shackles or not to add shackles that is the question! 1997_Sport YJ Wrangler Technical Forum 16 09-30-2009 07:39 AM
shackles bignateb YJ Wrangler Technical Forum 13 03-22-2009 01:30 PM
shackles jeepmud YJ Wrangler Technical Forum 3 12-07-2005 03:08 PM
MORE shackles standnstillfast YJ Wrangler Technical Forum 8 11-18-2005 03:28 PM
