All about shackles - Page 5 - JeepForum.com
post #61 of 99 Old 02-03-2009, 05:59 PM
jordanw_125
I would like to think that as well.. I'll PM you Barrio about a 2.5 lift.
jordanw_125 is offline
post #62 of 99 Old 02-04-2009, 06:32 PM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Originally Posted by jordanw_125 View Post
I bought some greasable boom shackles. They came off of a Jeep used, but they didn't come with bushings. Can I put rubber bushings in them, or am I restricted to greasable poly bushings? Are all bushings greasable?
Sorry it took me so long to reply, I was not on the forum while this thread was bumped, so I missed your question.
So long as the bushings are fluted they will work as expected with greasable bolts.
What is "fluted" you might ask?
Look inside the bushing. Do you see ridges molded into them that span the length of the bushing? Those are the flutes. Is it these flutes that hold the grease in there as well as allow it to work around the bushing pin.
I am not aware of any aftermarket "poly" bushings that do not come with these flutes.
Likewise, I am not aware of any rubber OEM replacement bushings that do come fluted. But that can eaily be remedied with thin rat-tailed file, or grooved guitar string, etc.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #63 of 99 Old 02-04-2009, 06:36 PM
jordanw_125
That's great. Thanks alot!
post #64 of 99 Old 02-04-2009, 06:54 PM
black954
1978 CJ7
Here's a question for you.
I'm building a CJ7 for the dunes on a budget. My main goals are to get a long travel suspension on leafsprings.
My plan is to do a shackle reversal up front and use YJ springs in the process mounted under the axle. I was thinking of using the superlift superide 3.5" springs with stock length boomerang shackles. I am making my own shock mounts for the longest travel shocks that fit under the hoodline up front and I was going to use the same length shocks in the back that will protrude through the rear floor mounting to a custom cross member spanning the rollcage. I was thinking of using the adjustable remote resevoir ProComp shocks in the 10"-12" travel length. I'd like to keep the center of gravity as low as possible to help with handling and I was planning on using a front sway bar also.
Any insight would be helpfull thanks!
black954 is offline
post #65 of 99 Old 02-04-2009, 07:12 PM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Are your plans to use stock length CJ shackles or stock length YJ shackles? YJ shackles are 4" bolt-to-bolt, whereas CJ shackles are 4" bolt-to-bolt.
I have actually put CJ size shackles on a YJ before, and they fit, but I don't think a center support bolt can be used in them (not 100% sure there)... although I don't see much of a chance of shackle inversion with 3" shackles on a YJ.
Or did I totally miss what you were getting at in your post?
in a (text only)
post #66 of 99 Old 02-04-2009, 07:27 PM
black954
1978 CJ7
I was going to use stock length YJ boomerang shackles with no center pin
black954 is offline
post #67 of 99 Old 02-04-2009, 07:30 PM
black954
1978 CJ7
I wasn't really getting at anything, I more just wanted to know your opinion on the set up i'm planning or your suggestions to get a long travel leaf spring suspension. You really seem to know what your talking about in leaf springs and shackles and I am going at this with no other direction than what I can speculate to work well.
black954 is offline
post #68 of 99 Old 02-04-2009, 07:33 PM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Ahhh, I see.
I think an open discussion would benefit you more than just my opinion to be honest. Most of the time I'm drunk and forget things.
And to be honest, I don't have enough experience with shackle reversals to give you an opinion on them that I would be happy with handing out. Yah, I'll admit that!
Seriously though, start an open discussion thread about it. I'm sure you'll get tons of useful stuff from many people, some more well versed than I... it's better than just one opinion.
in a (text only)
post #69 of 99 Old 02-04-2009, 07:36 PM
black954
1978 CJ7
will do, thanks
black954 is offline
post #70 of 99 Old 04-03-2009, 05:45 PM
rob1208lv
so i tried to install some shackles and followed all of brandon directions, and for some silly reason I couldn't even get the front ones in? The springs wouldn't line up with the frame. they where off to the right about 1". i had no problem moving the springs up or down, just couldn't from side to side.. is this normal I pryed the he double hockey sticks out of it and still no luck. I put the stocks back on for now.. I am thinking I'll just buy some posi style shackles to make my life easy.. any suggestions?
rob1208lv is offline
post #71 of 99 Old 04-03-2009, 06:47 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Front track bar still on? That is usually the thing that screws up most folks.
Remove the track bar (if you still have it on) and then install the new shackles. Then deposit the track bar in your favorite garbage can.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #72 of 99 Old 04-03-2009, 06:53 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
How dare you recommend that!
I do agree, the tracbar can cause issues when trying to install the leafs.
Joe Dillard is online now
post #73 of 99 Old 04-03-2009, 07:01 PM
rob1208lv
Max
I'll try that, so the track bar will cause the leaf to shift a inch t the right?
post #74 of 99 Old 04-03-2009, 07:50 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Pulled my setup 1/2" to the drivers side.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #75 of 99 Old 04-03-2009, 08:03 PM
rob1208lv
THATS where mine is pulling now, i need it to go the other way.
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 01:35 PM
To add shackles or not to add shackles that is the question! 1997_Sport YJ Wrangler Technical Forum 16 09-30-2009 06:39 AM
shackles bignateb YJ Wrangler Technical Forum 13 03-22-2009 12:30 PM
shackles jeepmud YJ Wrangler Technical Forum 3 12-07-2005 02:08 PM
MORE shackles standnstillfast YJ Wrangler Technical Forum 8 11-18-2005 02:28 PM
