All about shackles - Page 4 - JeepForum.com
post #46 of 99 Old 01-09-2009, 06:53 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Originally Posted by laxncj18 View Post
i just bought a jeep and the PO has regualr stock shackles on but it came with straight shackels that measure 6in so a 1in lift. Should i just wait til i get a lift to put them on even tho that wont be for a while since i have no money. I know you said the right way to get the lift is a sus. Can i still put on the shackles now or should i just wait for the lift? THanks
In my experience:
If your stock springs still have some arch left to them then you probably won;t hurt anything with the 1" lift shackles. If they are flat though, you run the chance of inverting the spring and actually losing lift when installing them.
Sorry for the delay, I was on vacation when you posted.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #47 of 99 Old 01-09-2009, 06:59 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Originally Posted by ninjzx998 View Post
Brandon, Great write up I read it after I did mine, just wanted to point out a couple of oversights in the first section for the front shackle install that would make it a litter clearer for noobs.
--OK, now you should have the shackles off and the bolts removed. In *most* cases the shackle-eye of the spring has curled up towards the spring,(S/B Frame) this is more common than it hanging lower (which happens on old stock or sagged springs).
The installation is pretty straight forward. Start by installing the shackle-frame end of the shackle first. But do not torque it down to specs just yet, just get it on there pretty good, a little side-to-side slop will help get the spring into the shackle easier.
As mentioned before, in most cases the spring has curled up towards the spring,(S/B Frame) This is where the bottle jack comes in to place.
Also wanted to add that a single high lift jack under the bumper will allow you to keep the wheel on the ground and will allow you to increase or decrease space for the shackles by jacking higher or lower (bottle jack may still be necessary)
PS if you edit original I will clear it out in my post to reduce clutter
typos fixed and accredited, thanks
no need to remove your post, I like clutter
in a (text only)
post #48 of 99 Old 01-09-2009, 07:06 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Originally Posted by HanksRide View Post
Great thread and info fer us beginners!!!
I just purchased what I understand to possible be Brandon_YJ's last set of shackles on ebay - atleast for awhile maybe - I have since been PM-ing him to death with questions before I actually read all of this great info. Sorry man The last PM that I sent I would like to repeat here since I don't see the answer anywhere and maybe the other noob's can pick up on it as well.
More info on bolts, and Bushings. Sizes, type, and sources of purchase. I understand that they need to be grade 5 or 8 but not sure on the dimentions exactly. I have also located some bushings on ebay from Daystar but I wasn't sure if all bushings are created equal and of the same size?
Any help in this area would be appreciated!!!
I just walked out and measured mine.
The shackle bolts are 4 1/2" long (including bolt head).
If you need new bushings you can probably save money by going to Autozone (or any other chain auto store) and ordering a set of "shackle frame" bushings and/or "shackle spring" bushings. Obviously, if your springs are newer then you probably won't need the shackle-spring bushings.
When ordering from a chain store you will usually have the option of getting stock rubber replacement bushings or poly bushings - and you get to save on shipping.
in a (text only)
post #49 of 99 Old 01-09-2009, 08:06 AM
Barrio
could you also cover SRS Brandon, that seems to be a touchy subject as well.
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #50 of 99 Old 01-09-2009, 08:17 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Let me do some research Barrio and I'll see what I can do.
It was the 5 posts a day for 2 weeks about shackles that prompted this thread.
But yeah, I've seen a bit of questions about SRS too.
in a (text only)
post #51 of 99 Old 01-09-2009, 08:26 AM
1997_Sport
Originally Posted by Brandon_YJ View Post
In my experience:
okay thanks ill have to go out and check if they are arched or flat. And no problem, thanks agian
1997_Sport is offline
post #52 of 99 Old 01-09-2009, 03:00 PM
Barrio
yeah lol
top asked question threads:
-SOA
-SYE
-Shackles
Barrio is offline
post #53 of 99 Old 01-11-2009, 04:38 PM
HanksRide
Can someone please tell me the measurements of stock shackles on a 95. I am not to sure the PO has not put something a little different on here??
HanksRide
(Hank is Yellow Lab) He loves it!!
95yj 4.0L, 4" RC Lift, 8.8, Aussie Locker, Posi-Lok, Rock Sliders, 1" Booms, 33 X 12.50's, Rhino Lining, KC Day Lighters, Rock Bumpers, LED Dash Lights, XRC10 Winch
HanksRide is offline
post #54 of 99 Old 01-11-2009, 04:42 PM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Stock shackles will measure 4" from the center of the top hole to the center of the bottom hole.
They are made from 11GA HRPO steel (about 3mm) and stamped to curl the edges which provides additional support.
in a (text only)
post #55 of 99 Old 01-12-2009, 01:00 AM
Barrio
happy 3000th post Brandon! lol
Barrio is offline
post #56 of 99 Old 01-12-2009, 01:11 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Oh damn.
I post too much.
in a (text only)
post #57 of 99 Old 01-12-2009, 09:18 AM
Barrio
Oh damn.
I post too much.
Same here. I need a life, oh wait Jeeps are my life nevermind.
Barrio is offline
post #58 of 99 Old 01-29-2009, 11:09 AM
spiicytuna
Stock shackles on my 1995 look like this (ignore the picture of the stock body bushings):
spiicytuna is offline
post #59 of 99 Old 02-03-2009, 12:41 PM
jordanw_125
I bought some greasable boom shackles. They came off of a Jeep used, but they didn't come with bushings. Can I put rubber bushings in them, or am I restricted to greasable poly bushings? Are all bushings greasable?
jordanw_125 is offline
post #60 of 99 Old 02-03-2009, 01:25 PM
Barrio
Im a strong beliver that one can lube anything. lol
Barrio is offline
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 02:35 PM
To add shackles or not to add shackles that is the question! 1997_Sport YJ Wrangler Technical Forum 16 09-30-2009 07:39 AM
shackles bignateb YJ Wrangler Technical Forum 13 03-22-2009 01:30 PM
shackles jeepmud YJ Wrangler Technical Forum 3 12-07-2005 03:08 PM
MORE shackles standnstillfast YJ Wrangler Technical Forum 8 11-18-2005 03:28 PM
