All about shackles - Page 3 - JeepForum.com
post #31 of 99 Old 11-24-2008, 10:49 AM
HGHSPEED
1987 YJ Wrangler
K, thanks I'll have to look into it, any recomondations? I've seen a few on here that are that way, but it seemed a lil odd to me. I'm a new jeep guy though so wasn't sure. Thanks again.
HGHSPEED is offline
post #32 of 99 Old 11-24-2008, 11:00 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
You've seen other Jeeps on the forum that don't have shackles in the rear?
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #33 of 99 Old 11-24-2008, 10:41 PM
HGHSPEED
1987 YJ Wrangler
My bad never mind, after a closer look I see what must be oem shackles. These are much smaller than the front and black verses the bigger non painted ones on the front. Since it's all black they blended right in! DAR!! Probably what I thought I was seeing with other pics as well. Is the larger shackels on front just for the added flex?
HGHSPEED is offline
post #34 of 99 Old 11-24-2008, 10:45 PM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Maybe the PO didn't have enough money to get two pair.
Or maybe they were installed to level the Jeep out.
in a (text only)
post #35 of 99 Old 11-25-2008, 02:40 AM
bigbelman2009
nice thread. i just thought id share what what i saw while driving down the road one day. a really nice looking lifted yj came off of a side street on rt 1. when i looked a little closer at it i noticed that the shackles had to be close to a foot long from bolt to bolt.
bigbelman2009 is offline
post #36 of 99 Old 11-25-2008, 04:28 AM Thread Starter
Brandon_YJ
1987 YJ Wrangler
Your mission now is to hunt down this YJ and take pics of us so we can start a "What Not To Do To Your YJ" thread.
in a (text only)
post #37 of 99 Old 12-19-2008, 11:34 PM
CaptainJaxx
Brandon, great information. Can you explain what a "greaseable" shackle is, and it's purpose?
CaptainJaxx is offline
post #38 of 99 Old 12-19-2008, 11:58 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Greaseable shackles will come with bolts that are like this. They'll have a grease fitting at one end and the bolt is specially gun-drilled so that grease passes thru the bolt and exits the bolt in the sleeve area of the bushings.
This allows the sleeves & bushings to "glide" as they rotate within the eye of the leaf springs because of the grease. It also quiets them down and has less friction which allows the suspension to cycle more freely.
Joe Dillard is offline
post #39 of 99 Old 12-20-2008, 12:25 AM
CaptainJaxx
Thanks! So can you put these bolts in any shackles? Or do they have to be specific shackles made for this type of bolt?
post #40 of 99 Old 12-20-2008, 12:28 AM
burntoutfireguy
Excellent explanation... I was thinking of going and getting me some shackles soon to compliment my 4" lift that i will be recieving on tuesday. This thread has really helped me consider what size shackles i want. And i love that you put a pic for the greasable shackles. excellent pic with a great explanation.
89 YJ. 4.2L W/ Weber. Converted to AX15. 4" RC Lift, 1" BL, 32" Courser MXT's.
burntoutfireguy is offline
post #41 of 99 Old 12-20-2008, 01:29 AM
Joe Dillard
As long as the bolt is the right size, yep, you can install 'em in an application that didn't already have the greaseable bolts.
What I like to do prior to assembly is, I grease the leaf spring eye by hand, as well as the bushings and sleeves. This helps to ensure grease is already in areas where it would take time to penetrate and cover the friction areas. I also like to grease my leaf pads and areas where high friction tends to be in the suspension.
post #42 of 99 Old 12-20-2008, 01:38 AM
RikRotorhead
You have a link to a site/supplier of said bolts, to enhance your description?
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #43 of 99 Old 12-28-2008, 10:15 PM
1997_Sport
i just bought a jeep and the PO has regualr stock shackles on but it came with straight shackels that measure 6in so a 1in lift. Should i just wait til i get a lift to put them on even tho that wont be for a while since i have no money. I know you said the right way to get the lift is a sus. Can i still put on the shackles now or should i just wait for the lift? THanks
1997_Sport is offline
post #44 of 99 Old 01-08-2009, 07:41 PM
HanksRide
Great thread and info fer us beginners!!!
I just purchased what I understand to possible be Brandon_YJ's last set of shackles on ebay - atleast for awhile maybe - I have since been PM-ing him to death with questions before I actually read all of this great info. Sorry man The last PM that I sent I would like to repeat here since I don't see the answer anywhere and maybe the other noob's can pick up on it as well.
More info on bolts, and Bushings. Sizes, type, and sources of purchase. I understand that they need to be grade 5 or 8 but not sure on the dimentions exactly. I have also located some bushings on ebay from Daystar but I wasn't sure if all bushings are created equal and of the same size?
Any help in this area would be appreciated!!!
HanksRide
(Hank is Yellow Lab) He loves it!!
95yj 4.0L, 4" RC Lift, 8.8, Aussie Locker, Posi-Lok, Rock Sliders, 1" Booms, 33 X 12.50's, Rhino Lining, KC Day Lighters, Rock Bumpers, LED Dash Lights, XRC10 Winch
HanksRide is offline
post #45 of 99 Old 01-09-2009, 05:45 AM
ninjzx998
Brandon, Great write up I read it after I did mine, just wanted to point out a couple of oversights in the first section for the front shackle install that would make it a litter clearer for noobs.
--OK, now you should have the shackles off and the bolts removed. In *most* cases the shackle-eye of the spring has curled up towards the spring,(S/B Frame) this is more common than it hanging lower (which happens on old stock or sagged springs).
The installation is pretty straight forward. Start by installing the shackle-frame end of the shackle first. But do not torque it down to specs just yet, just get it on there pretty good, a little side-to-side slop will help get the spring into the shackle easier.
As mentioned before, in most cases the spring has curled up towards the spring,(S/B Frame) This is where the bottle jack comes in to place.
Also wanted to add that a single high lift jack under the bumper will allow you to keep the wheel on the ground and will allow you to increase or decrease space for the shackles by jacking higher or lower (bottle jack may still be necessary)
PS if you edit original I will clear it out in my post to reduce clutter
ninjzx998 is offline
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 01:35 PM
To add shackles or not to add shackles that is the question! 1997_Sport YJ Wrangler Technical Forum 16 09-30-2009 06:39 AM
shackles bignateb YJ Wrangler Technical Forum 13 03-22-2009 12:30 PM
shackles jeepmud YJ Wrangler Technical Forum 3 12-07-2005 02:08 PM
MORE shackles standnstillfast YJ Wrangler Technical Forum 8 11-18-2005 02:28 PM
