Alignment Specs with 4" RC lift and 1" Boom shackles
#1 | |
I have just installed my 4" RC lift and 1" boom shackles. What should the Caster, Camber angles be set at?
1/8" toe out to will help with very slight death wobble?? Yes?? Yes all ball joints, tie rods and drag link have been replaced. I have 33X12.5 tires on 15X10 black steelies.
#2 |
Everything back to stock settings.
#3 |
Really caster and camper didn't move much with springs. You may need to adjust toe but other than that it should just about stay stock.
#4 |
What else can be adjusted or changed to stop very slight wobble in front. Tires and rims both roll true on balancer, all ball joints, tie rods and drag link have been replaced, along with steering stablizer. Any help there?? Thanks!
#5 |
Was a Drop pit man arm installed when the lift was installed?
#6 |
yes, the full RC 4" kit was installed
#7 |
Can you post a picture of the drag link and tie rod?
#8 |
if you added one inch to your shackles your caster is off. you will need to go back to stock or shim the springs to return.
i've learned that alignment is a MUST with a raised jeep. it's not like a low four door car and only the tires will scrub. the jeep needs it's toe right. |
#9 | ||
Caster in Degrees (Decimal) ................ 7.0 to 8.0 Toe-In in Inches (Fraction) .............. 1/16 to 1/8 Steering Axis Inclination (SAI) ................ 8 1/2* Max ![]()
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#10 |
Thanks for all the help, my Caster is set at 8*, my toe was set a bit more than normal 3/8" toe in, camber is at stock spec! I run a shop and have two alignment machines with a 30 year veteran at alignments but he is great at OEM type work. Once i gave him the new spec and we played with it a few times it is perfect now, as far as driveability that is any way. We set it, then drove, set it again, then drove it again, set it the last time and she was awesome!
#11 | ||
Max ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
