Alignment? - JeepForum.com
post #1 of 19 Old 02-08-2013, 03:39 PM Thread Starter
chuck172
Alignment?
After replacing just about all my front end parts, I still have some steering wander. My wheel doesn't return fully to center either. I have the symptoms of the caster out of spec.
I do my own toe-in, simple, but checking caster is more difficult. YJ's have a solid axle, and the caster is factory set. My jeep is totally stock. No lift and stock shackles.
Should I get an professional alignment to rule out caster problems for certain?
chuck172 is offline
post #2 of 19 Old 02-08-2013, 04:21 PM
jokerchief462
Your alignment is set a zero meaning front and read measurement at the wheels or tires should be the same. Check it out.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 19 Old 02-08-2013, 04:42 PM
jbolty
jbolty's Avatar
Other than toe in there is nothing to align or adjust.
How are the ball joints?
You can shim the axle to adjust the caster but why would it be off? Stock springs? Are they sagged?
Take some pictures.
jbolty is offline
post #4 of 19 Old 02-08-2013, 05:36 PM Thread Starter
chuck172
[QUOTE=jbolty;14933139]Other than toe in there is nothing to align or adjust.
I understand that, there really is no need for a professional wheel alignment since my setup is totally stock. The caster can't be out of spec. I have new front springs, and ball joints, so I guess an alignment would be a waste of $$.
chuck172 is offline
post #5 of 19 Old 02-08-2013, 06:28 PM
timatoe
timatoe's Avatar
Mean Max has a write up on doing a home alignment. I used his write up to do mine, easy breezy.
timatoe is offline
post #6 of 19 Old 02-08-2013, 06:37 PM Thread Starter
chuck172
Setting toe is simple, caster is more difficult, but really isn't ever needed with a stock jeep. Correct me if I'm wrong but setting caster should be taken out of the equation if dealing with a totally stock yj, with new springs.
My wandering and steering wheel return to center problems must be caused by something other than an alignment.
chuck172 is offline
post #7 of 19 Old 02-08-2013, 08:45 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
If the toe adjustment doesn't fix your problem, some alignment shops will just give you a readout of the settings, with no changes made, for $20 or so. With that, you can see if there are any camber/castor issues. Their shouldn't be, but it's an old truck, and crap happens. Mine had the camber off on one side and I fixed it with an adjustable ball joint (Moog 'Problem Solver' series).
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #8 of 19 Old 02-08-2013, 08:56 PM Thread Starter
chuck172
What caused your camber to be off? How did it affect your handling?
chuck172 is offline
post #9 of 19 Old 02-08-2013, 10:08 PM
bill8bud
I am off by 2° on my passenger side. Anyone know where to get the aims from mentioned in this post.
http://www.jeepforum.com/forum/f8/ca...-shims-447962/
http://www.jeepfan.com/tech/adjusting-camber/
bill8bud is offline
post #10 of 19 Old 02-09-2013, 03:44 AM Thread Starter
chuck172
Is your axle bent bill8bud?
chuck172 is offline
post #11 of 19 Old 02-09-2013, 07:07 AM
JeeperDon
JeeperDon's Avatar
I bought the Jeep stock, used, in 1996 with 95k miles on it. It pulled to the right since my day one with it (I know, 15 years of holding left steering wheel, pretty dumb). To answer your question, I have no idea how the camber got buggered.
I didn't rotate the current set of tires often enough and now they are pretty buggered with alignment problems. So, before getting new tires next month I decided to finally get the alignment right. Firestone dealer here in Abq did a 'check' for $21, and I needed/did an adjustment via one adjustable ball joint.
Web Admin for
post #12 of 19 Old 02-09-2013, 08:10 AM
bill8bud
I would say something is off..
bill8bud is offline
post #13 of 19 Old 02-09-2013, 08:34 AM
Darold
My steering wheel did not return to center and steered a little hard. I fooled with everything, nothing helped. Looked at the steering box adjustment and there was none, so loosened the nut and backed the adjustment bolt out all the way , then started to turn it in as needed. Happens that it only needed a little adjustment inward. It had been over adjusted! Worth a try.
Darold is offline
post #14 of 19 Old 02-09-2013, 09:30 AM
bill8bud
Correction I am .5° off
Toe in has been fixed
bill8bud is offline
post #15 of 19 Old 02-09-2013, 09:48 AM
timatoe
timatoe's Avatar
Where did you take it and get that print out? Just out of curiosity since I still get a slight shimmy at times.
timatoe is offline
