Airbox - JeepForum.com
post #1 of 22 Old 02-17-2007, 01:38 PM Thread Starter
geabaldyvx
Airbox
OK.. so my newly aquired YJ as been sounding funny.. at least to me it sounded funny... The guy I bought it from told me the previous people before him had but this cone style air-intake on it and that was what was making the racket I was hearing..
So, it was warm enough today and he had no idea when the last time the plugs, wires, dist cap and rotor were replaced so I decided to go ahead and do them. Pop the hood and low and behold, there it is.. looks like something even a ricer wouldn't put on his car... what is worse is they zip tied the damned thing to the steel brake lines off the master cyl... So, now I am in the hunt for a stock airbox to put back where it should and get rid of that awful noise it has created.. not to mention the fact that the hose off the top of the motor that runs back down to the airbox is just pushing it out onto the firewall.. again I am thinking this is creating a wonderful condition where my motor sounds like complete crap...
So, here is the deal.. Where exactly does that hose off the top of the motor run to? Am I right in assuming I am losing MPG or HP because it isn't in a closed system and is allowing cold air down into my motor not to mention anything else that happens to decide to find a new home?
geabaldyvx is offline
post #2 of 22 Old 02-17-2007, 01:44 PM
paintguy
the hose is your PCV (positive crankcase ventilation) hose -- it runs to and connects to the top of the stock airbox -- where is it running now? It just lets the valve cover "breath" so you are not loosing hp/mpg unless it is just block off and not letting the valve train "breath" -- if when you remove that inlet from the valve cover (oir the oil cap) and it is blowing a lot of air out that means you have piston ring "blow-by".
What motor do you have, the I6 or I4?
Pray For World Peace and Love -- This is all the World Needs, and ever needed -- Everything else will follow...
paintguy is offline
post #3 of 22 Old 02-17-2007, 01:49 PM Thread Starter
geabaldyvx
I have the 4 banger.. and right now it is pointed at my firewall and not connected to anything...
post #4 of 22 Old 02-17-2007, 02:16 PM
93YJfalcon
Just a thought, but if you back to the stock airbox it will make your motor more vulnerable during deep water crossings since it moves the intake to just below the front left headlight.
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
post #5 of 22 Old 02-17-2007, 02:18 PM Thread Starter
geabaldyvx
I'm not going mudding anytime soon.. and right now enough rain coming through the grill will put water into this ricer POS that is on there... makes K&N look like the Rolls Royce of filters...
Been looking at one of the AirAid boxes as an alternative even thought they use the silly cone style filters at least it is actually made the vehicle and not something that was meant to be the intake for a 3 cyl Geo Metro to make it sounds like it had 1 more cyl...
post #6 of 22 Old 02-17-2007, 07:24 PM
Jeeples
Jeeples's Avatar
So you bought a Jeep without looking under the hood first?
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #7 of 22 Old 02-17-2007, 08:37 PM Thread Starter
geabaldyvx
LOL.. honestly... Yes... but I also bought it from someone I trust... and I know he had looked under the hood... he told me about some of the screwball stuff under their... and most of isn't anything to worry about... besides.. it needs a new slave cyl and the 4wd wasn't working.... he fixed the 4wd and has it scheduled to get the slave fixed... he doesn't even own it and it's been paid for to be fixed.. like I said not worried... other than a few computer controlled items like FI... it isn't any harder to work on than my binder was..
post #8 of 22 Old 02-18-2007, 06:00 AM
RealJeep
Wow, I would never buy a car without looking under the hood. Just get a K&N and throw it in there.
1992 Wrangler Sahara, 4.0L HO, Dynomax exhaust, Kc daylighters, 4" pro comp suspension lift, 33x12.50 BFG MT's, 15x10 rockcrawlers, hurst shifter, Off-road bumpers, SYE, 2-10's, MM 8000 Winch, ARB Snorkel, MORE Boomerangs, CB
RealJeep is offline
post #9 of 22 Old 02-18-2007, 06:04 AM
got_4_lo
we can't give you advice until we see a picture of this intake.
hopefully a simple K&N or AFE will be all it needs.... but you might need to replace the intake tubing if it's redneck-engineered enough.
-Shayan A.K.A: Sean
Originally Posted by DesertTJ
I came home to be spit on and protested against in Boulder, Colorado. Most of the people have no clue. And that's why we do what we do. We give up our freedom so they can enjoy their freedom.
got_4_lo is offline
post #10 of 22 Old 02-18-2007, 07:56 AM
paintguy
check this out -- anybody ever seen or used this?
http://cgi.ebay.com/ebaymotors/ws/eB...m=230093316496
paintguy is offline
post #11 of 22 Old 02-18-2007, 09:17 AM
Monk89 94 I4
and your assuming that the ziptied no cover cone is much better?
94 was a great year for the yj, 2006 was a great year when i put the sport cage in it...
Monk89 94 I4 is offline
post #12 of 22 Old 02-18-2007, 02:09 PM Thread Starter
geabaldyvx
Ask and ye shall receive... here are photos of my rig.. along with the redneck engr. airintake
The Old Toy...
The New Toy...
The Intake
post #13 of 22 Old 02-18-2007, 02:47 PM
93YJfalcon
MUCH better... no. Higher though. It sounds similar to what I use when I go mudding (not often- I hat ethe cleanup and everything grinds and squeeks after). Normally I use the stock airbox, but I have a clamp on air filter that moves the intake up about 6 inches and puts it farther back by the battery (since water crossing kind of pushes a wave in front of you that makes the water deeper on the grill).
post #14 of 22 Old 02-18-2007, 02:52 PM
got_4_lo
The Old Toy...
The New Toy...
The Intake
forbidden - linky no workie
-Shayan A.K.A: Sean
got_4_lo is offline
post #15 of 22 Old 02-18-2007, 02:53 PM
got_4_lo
I wouldn't touch those with a 10 foot pole. especially the filter.
-Shayan A.K.A: Sean
got_4_lo is offline
88 2.5l Oil In Airbox? FSTG60MAN YJ Wrangler Technical Forum 6 09-13-2009 10:34 AM
OEM Airbox ? SuperWade2 TJ Wrangler Technical Forum 7 07-28-2007 08:49 AM
Airbox? Are they the same? onlyn8v TJ Wrangler Technical Forum 2 07-15-2007 07:41 AM
Oil in Airbox? dabomb5756 YJ Wrangler Technical Forum 4 04-23-2005 11:35 AM
Oil in airbox YJ boy YJ Wrangler Technical Forum 5 02-22-2002 11:15 PM
