Air Horn - JeepForum.com
post #1 of 7 Old 05-19-2001, 09:49 PM Thread Starter
InspGadgt
Air Horn
Heyyas Folx, Anyone install a Dual Air Horn system in their YJ? Picked up a WOLO today & took a look. Trying to figure out WHERE!!! LOL
sp8r
-= IG =-
InspGadgt is offline
post #2 of 7 Old 05-20-2001, 09:28 PM
wilhelm
try either removing or moving the factory horn assembly or where the factory jack is under the hood.
wilhelm is offline
post #3 of 7 Old 05-21-2001, 10:50 AM
damonejeep
The install is easy. I attached the air compressor to the post where the old horn was, and placed the two horn cones behind the compressor wedged in between the air filter and the wheel fender. If there is no room there, just look for a place where there is room and either wedge them in or screw them in. Install took me about 1/2 hour.
Good luck
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
post #4 of 7 Old 05-21-2001, 11:11 AM Thread Starter
InspGadgt
thanks. I "THOUGHT" I could use the existing wiring, but since I've read thru the install notes, guess not.
Can I use the existing horn button (sterring wheel) tho?
Thanx much
-= IG =-
-= IG =-
post #5 of 7 Old 05-21-2001, 02:21 PM
horatio102
You are yousing a relay, right?
Marked 30, 85, 86, 87.
30 goes to the battery
85 I think is the ground
86 should be where you plug the factory horn wire in
87 goes to the compressor.
That's all from memory though. Check the instructions. Where it says switch, just use the factory wires.
horatio102 is offline
post #6 of 7 Old 05-22-2001, 10:47 AM
damonejeep
Horatio is right. Just go slow and the job is not that difficult.
Andrew
post #7 of 7 Old 05-22-2001, 11:09 AM Thread Starter
InspGadgt
Thanks guys. I can field strip an m16 blind, & the same with a computer (& reassemble),but anything more than putting gas (and oil when the wife reminds me) into a car & I'm an idiot. Suggestions on where to tie into the positive for power?
Thanx much
-= IG =-
-= IG =-
My horn is shot, shopping advice for a loud horn cj5mudman4x4 TJ Wrangler Technical Forum 7 07-28-2011 02:36 PM
Horn wont work, relay and fuse ok and horn works if direct wired Redskin TJ Wrangler Technical Forum 5 01-02-2010 04:24 PM
Hooking up aftermarket horn to '94 YJ. . .OEM horn wiring diagram??? atomicjoe23 YJ Wrangler Technical Forum 14 07-21-2009 06:39 PM
Anemic JK horn fixed! - Air Horn Install tturkstra JK Wrangler Technical Forum 11 10-03-2008 09:04 AM
Removed horn pad and the 3 screws underneath the horn pad - help Rocky529 YJ Wrangler Technical Forum 4 05-20-2006 05:48 PM
