Air cleaner - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Air cleaner
Savvy Aluminum Gas Tank SkidFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Stainless Steel Door Hinge Pins
Unread 06-01-2014, 03:02 PM   #1
jasonjones21
Air cleaner
89 4.2 with carter bbl, is there a air cleaner that looks like this one that could still plug in to most of the main vacuums lines? Or do I really need those vaccine lines hooked
jasonjones21 is offline   Reply With Quote
Unread 06-01-2014, 04:36 PM   #2
NonRubicon
There are no CARB approved aftermarket air filter housings for the factory 4.2L YJ. If you had Howell TBI you could use that type of filter, but for the factory 4.2L you need the stock air cleaner and everything hooked up to it as it was from the factory to be able to pass smog in California. Without the factory air cleaner you'll fail visual and you'll fail the sniffer. The factory air cleaner has a temperature sensor that the computer needs a signal from in order to put the computer into closed loop mode. Without the proper signal, the computer will remain in open loop mode and run too rich. Even if you modified an aftermarket housing to accept all the vacuum lines, it would still fail visual.
Since you have the 4.2L and you are in CA, you'll want to check out Adventures Under the Hood for all the info you'll need to keep it running well enough to pass smog. The best advice I can give for anyone in CA who has a 4.2L YJ that is registered for the street is to consider going Howell TBI or swap in a 4.0L engine from a 1991-95 YJ. The factory Carter BBD setup in the 4.2L YJ requires a lot of patience to maintain and some parts for the emissions components are no longer made.
NonRubicon is offline   Reply With Quote
Unread 06-01-2014, 05:08 PM   #3
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
You reside in California if you stray from the stock air cleaner someone will get cancer and they will pass another law or close a trail
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is online now   Reply With Quote
Unread 06-01-2014, 06:03 PM   #4
jasonjones21
Alright now what about in CO is there any issues about smog out there thinking of moving there soon
Unread 06-01-2014, 06:05 PM   #5
jasonjones21
Brookfield area
Unread 06-01-2014, 06:18 PM   #6
Old4X
1990 CJ7
Denver area has testing, even if you only work in the affected area and live outside.
Rust free YJ for sale. Need more room in barn.
Old4X is offline   Reply With Quote
Unread 06-01-2014, 06:32 PM   #7
Chrisnvegas
Is keeping a clean, properly running engine so difficult? California's air has stayed the same despite the population quadrupling. It's because of clean air standards.
That air cleaner is a piece of crap. I call it the "hot air intake"
It will be sitting only several inches above you hot exhaust manifold and will also be sucking in hot air freshly washed through your hot radiator. If that's the kind of performance you're looking for, go for it.
Do not write in this area, for office use only.
Chrisnvegas is offline   Reply With Quote
Unread 06-01-2014, 06:52 PM   #8
jasonjones21
Is cold air intake any good for 4x4s?
Unread 06-01-2014, 07:26 PM   #9
Tom95YJ
Tom95YJ's Avatar
Arb safari snorkel
Unread 06-01-2014, 07:36 PM   #10
Chrisnvegas
Cooler air is more dense than hot air. That means more air for combustion. That's a good thing.
Be aware that the high elevation in Colorado will result in up to 20-25% instant loss in power. Thinner air.
Not a reason not to move there, just keep in mind your Jeep will be pretty doggy there compared to sea level.
Unread 06-01-2014, 09:10 PM   #11
jasonjones21
What could I do to keep it up to speed
Unread 06-01-2014, 09:17 PM   #12
Chrisnvegas
Where? There at home or Colorado?
Unread 06-01-2014, 09:43 PM   #13
Tom95YJ
Tom95YJ's Avatar
Rejet the carb and regear if not already done
Unread 06-01-2014, 10:08 PM   #14
jasonjones21
Thanks and in co
Unread 06-01-2014, 10:26 PM   #15
Tom95YJ
Tom95YJ's Avatar
Thanks and in co
Sea level requires different jets then at altitude.
