air cleaner - JeepForum.com
post #1 of 4 Old 02-15-2006, 04:52 PM Thread Starter
NYCjeep
NYCjeep's Avatar
air cleaner
Ok so I pretty much got the vacuum mess taken care of now im trying to get the air filter housing on the engine and its just not lining up correctly. I have the 4.2 and from what I can tell there is the part that gets bolted to the valve cover ( I have a bracket for that ) and the top part that goes over the air filter to the carb. I just cant seem to fit it on top of the valve cover correctly,, is there some kinda spacer that goes between the bracket and the housing??? Thanks a lot.
NYCjeep is offline
post #2 of 4 Old 02-16-2006, 12:07 PM
dbguync
If you're talking about the factory air filter housing, when I had mine on i had to put a few washers on the bracket on the valve cover to raise the housing up to fit. That bracket is adjustable side to side also. If your's is broke, I have the bracket and the housing I'm not using anymore...
87 YJ, 3.5 BDS kift, 33x12.5 ProComp MT's, 4.2, Nutter bypass, Weber carb, HEI ignition, Lockrite in the front , 8.8 in the rear, 456 gears all around. Oh, and a warn winch, etc, etc, No money left,
dbguync is offline
post #3 of 4 Old 02-16-2006, 12:24 PM
Wif
Wif's Avatar
Mine had a thick space/washer that went between the v/c and airbox
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #4 of 4 Old 02-16-2006, 02:27 PM Thread Starter
NYCjeep
NYCjeep's Avatar
thanks for the help guys someone sent me a pic i just have to find some washers fot it
NYCjeep is offline
Cleaner? newguy66 JK Wrangler Technical Forum 6 03-15-2008 09:44 AM
Oil in air cleaner? drtdvl YJ Wrangler Technical Forum 10 06-15-2005 01:32 PM
Air Cleaner C2U5H TJ Wrangler Technical Forum 3 01-11-2005 11:32 AM
Oil in Air Cleaner? soxfann YJ Wrangler Technical Forum 12 12-06-2004 10:50 AM
What is the name of that cleaner? jeeptoplesstx TJ Wrangler Technical Forum 5 04-27-2004 07:50 AM
