ahhh!?!? - Page 3 - JeepForum.com
post #31 of 57 Old 08-23-2011, 12:21 PM Thread Starter
19renegade91
im so sorry im the stupid one lol ...over looked that fact of the code reader lol appologies!. codes are 12 33 21 24 55
19renegade91 is offline
post #32 of 57 Old 08-23-2011, 12:25 PM Thread Starter
19renegade91
code 12 is direct battery imput disconnected within the last 50 starts...which i do not remember unhooking the battery...21 neither lean or rich dectet by o2 sensor...prob cause i unhooked it to see if it made a difference...it diddnt really...33 shorted AC CLUTCH RELAY i do NOT have AC..24 TPS above or below acceptable voltage it diddnt read above or below voltage that i could tell...55 end of message lol
post #33 of 57 Old 08-23-2011, 12:39 PM
oldtime_ironman
codes
Code 21 is oxygen sensor (O2 sensor) or circuit
Code 24 is throttle position sensor (TPS) or circuit
The other codes are pretty normal:
12 is the battery was disconnected before
33 is A/c relay (this doesn't matter if you don't have air conditioning)
55 is end of codes
Hope that helps!
oldtime_ironman is offline
post #34 of 57 Old 08-23-2011, 12:40 PM
jms2021
http://www.jeepforum.com/wiki/index....k_Engine_Codes
*edit* I was too slow lol!
jms2021 is offline
post #35 of 57 Old 08-23-2011, 12:41 PM
Que89YJ
21 is the O2 sensor and 24 is the Throttle position sensor. Because you have the codes does mean they are bad, it means they were out of the expected range for the ECU. The O2 is ususally thrown by 1 of 3 conditions 1) bad O2 sensor 2) cracked or lose bolts on the exhaust manifold (look at the bolts in the rear of the exhaust or a crack especially near the collector tubes) or 3) a fuel pressure issue. The TPS is either a bad sensor or a fuel pressure issue. Start by checking for a cracked exhaust since its the easiest. I have a feeling though that the common issue is fuel that you need to rent a fuel guage and see what it says when you are running into the problem. You should be between 31-39 psi.
Que89YJ is offline
post #36 of 57 Old 08-23-2011, 12:51 PM
oldtime_ironman
^^^ X2 the fuel is the common issue between the two
post #37 of 57 Old 08-23-2011, 01:27 PM Thread Starter
19renegade91
i think i mentioned that i had 31 psi and 40 wit vacc dissconected...and a pint of fuel pretty quick ..
post #38 of 57 Old 08-23-2011, 01:28 PM Thread Starter
19renegade91
the manifold is starting to crack but i cant see it leak yet ...its not black around the crack or anything
post #39 of 57 Old 08-23-2011, 01:29 PM Thread Starter
19renegade91
if the TPS is bad . would it explain why its always from 3/4 to open throttle that it mess up performance
post #40 of 57 Old 08-23-2011, 01:33 PM
oldtime_ironman
Yeah the TPS would explain a lot. BUT you should know that a cracked exhaust manifold can throw off the oxygen sensor. No matter how small the crack is. Lots of guys here have pulled their hair out over that one.
post #41 of 57 Old 08-23-2011, 01:43 PM
Que89YJ
Check the sensors and exhaust then.
Que89YJ is offline
post #42 of 57 Old 08-23-2011, 02:03 PM Thread Starter
19renegade91
the exhaust is not leaking near the mani.. infact its not leaking anywhere i can tell exept where its suppose to exit the pipe lol ...espically not near the o2 sensor...and i assume it said the o2 sensor cause i have been driving it with it unplugged to see if it make a difference in performace...it diddnt...its now plugged in again and after driving awhile again i will check codes again to see if it does go away..the only code i cant explain for is the TPS...the manifold is starting to crack at a weld though near the collecter pipe but its not leaking there yet...ill post back tomorow with results..sorry for being a pain
post #43 of 57 Old 08-23-2011, 02:06 PM
oldtime_ironman
the exhaust is not leaking near the mani.. infact its not leaking anywhere i can tell...espically new the o2 sensor...and i assume it said the o2 sensor cause i have been driving it with it unplugged to see if it make a difference in performace...it diddnt...its now plugged in again and after driving awhile again i will check codes again to see if it does go away..the only code i cant explain for is the TPS
Make sure to clear out the old codes by disconnecting the battery for a few seconds first. Then get back to us with whatever codes it shows after that.
post #44 of 57 Old 08-23-2011, 02:24 PM Thread Starter
19renegade91
yes disconnect battery thats what i ment haha sorry ill let you guys know tomomow im signin off now .thanks so much for your help
post #45 of 57 Old 08-23-2011, 02:34 PM
Que89YJ
You need to disconnect the battery to clear the fall codes. Drive it for 20 minutes to get it to go into closed loop and read all the sensors. Then re check fault codes.
Que89YJ is offline
will not start ahhh Brown6041 YJ Wrangler Technical Forum 4 12-23-2008 12:29 PM
ahhh! its never ending ErnieG TJ Wrangler Technical Forum 11 02-24-2008 03:37 PM
AHHH help stimulatechamin TJ Wrangler Technical Forum 8 09-26-2006 08:47 PM
ahhh i have had it jeepinjc YJ Wrangler Technical Forum 22 04-19-2006 08:17 PM
ahhh, v-8 confusion! youngjeeper11 YJ Wrangler Technical Forum 21 06-09-2005 08:43 AM
