Aggressive MT's with road performance - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Aggressive MT's with road performance
Smittybilt Products at Oconee Off-Road!Get DBA Brake Rotors From ExtremeTerrain.com!Poison spyder items @ oconee off road 706 534 9955
Unread 10-09-2014, 09:37 AM   #1
jaycal3
My Jeep is getting a full overhaul... I am in the process of fixing all the rust and will be repainting and/or Monstalining inside and out...I have the 4.5" of lift between the BDS springs and minimal BL along with 1/2" Besrk booms...now it's time for tires (mine need replacing anyway) and wheels... I want a mud tire for its performance on trails but also want one that will wear and perform decent on the road. I was considering Mickey Thompson Baja MTZ's or Dick Cepeks, and had also looked at KM2's and Kevlars... They are all kind of on the same price range.... What has the meanest or most aggressive look and will still perform in both trail and road.
I understand there are reviews out there and have read many...and I'm also looking for opinions which is subjective... But figured I'd throw it out there anyway. I would be going 33x12.5x15 on a 15x8 most likely....
Thanks,
Sent from my iPhone using JeepForum... So excuse the typos, my iPhone is challenged.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms
KCCO
jaycal3 is online now   Reply With Quote Quick reply to this message
Unread 10-09-2014, 09:48 AM   #2
Randonexplosion
Trailer Queen
Randonexplosion's Avatar
I am sure that the MTR/k's are going to be at the top of that list since that is what they were designed for. I don't have any experience with any of the tires that you listed but my STT's do well offroad and have decent road manners.
5.3/4l60e swap
August YJOTM
Exiled Offroad - Colorado
Randonexplosion is offline   Reply With Quote Quick reply to this message
Unread 10-09-2014, 10:10 AM   #3
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Ive run everything from Swamper TSL's to KM2's over the years. in my area the 3 most popular tires on the Dual Purpose rigs are KM2, MTR, and Red Letter General Grabbers.
I personally have KM2's on one of my Jeeps and they are one of the best tires Ive owned. the Red Letter grabbers are a little better on road mainly cause their tread pattern but off road the KM2's do excell mainly cause they hook up on slick rock better then the general. my KM2's on the XJ have 20K miles on them and they are at about 50% tread left once they wear out I'll buy another set if I dont try MTR's
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 08:39 PM   #4
DirtKar
I pledge allegiance.
DirtKar's Avatar
You are correct in that opinions are subjective. I will be going with the MTR/K's again when my current set wears out. Good road manners and performed beyond my expectations on the Rubicon.
What you see as not bad, and what I see as not bad, are two completely different not bads
YJOTM JULY 2014
DirtKar is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 10:28 PM   #5
JohnnyZJ
JohnnyZJ's Avatar
nothing you have listed are bad.
all are good choices.
they will all be loud, with a few vibes here and there; but all good tires that will suite your purpose. happy shopping
92 YJ ~ locked rollin' on 35s
05' WK Hemi limited ~ wifey mobile
13' Chevy Cruze ~ boo
13' GMC Sierra ~ 2.5" lift 33" MTs.
RIP 95 ZJ ~ 33s built/longarmed/locked/awesome Feb 2014 ZJOTM winner
JohnnyZJ is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 11:08 PM   #6
timatoe
I don't know if they're the "meanest or most aggressive" looking. But I've had a set of Dunlop Mud Rovers on mine for over four years and they've certainly preformed well on the trail and street. Price was nice too. I had old school MT/R's prior to that on 33's and they were nice too, but no one had those in 35's when I needed them.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 10-11-2014, 07:35 AM   #7
Jeepsr4me
I like Cooper and the good year Kevlar
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 10-11-2014, 04:05 PM   #8
jserna
1987 YJ Wrangler
I really like the TOYO mts.
jserna is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 05:52 AM   #9
Cobra Jeep
I have a set of BFG radial mud terrain TA/KM. I have had them for many years and many miles. On my YJ they have been giving great street wear and manners, and really arnt that noisy compared to other mud tires I have run/seen. I would highly recommend them for a dual purpose rig (like mine)
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, WJ knuckle/brake conversion, hydroboost. Warn M10000 winch. Hope to some day build a stroker for it.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Future mods: NV4500, NP205, high pinion D60 front and smooth bottom D60 rear, e-lockers front & rear. SOA with 35X12.50's
Cobra Jeep is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 03:48 PM   #10
medic-11
Ive got Treadwright Guard Dogs on my YJ. https://www.treadwright.com/individu...265-70R16.00-D
So far off road they do pretty good- I don't wheel much but I haven't gotten stuck yet. On the street they do make some noise but I don't consider it too bad. I run soft tops, and sometimes no doors, and it doesn't bother me. I have about 15k miles on them so far and they have worn very little. As for vibes- I had one tire cup a little and it turned out to be a bad front wheel bearing. I moved that tire to the other side after replacing the bearing, and it should probably be rebalanced. Because of that, I have a small vibration around 65 MPH. Other than that I can run 80-85mph on the highway with one hand on the wheel.
In the rain, I used to have a lot of wheelspin from a stop with 235/75-15 goodyear wrangler radial's, with these 265/70-16's- I can barely spin them.
medic-11 is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 04:41 PM   #11
JohnsonKen1332
Mickey Thompson Baja claw or NITTO mud grapplers
JohnsonKen1332 is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 06:51 PM   #12
jaycal3
Thanks for all the replies guys. As I do with everything, I over-research... I just found a ton of great reviews on the Super Swamper TSL Radial... And they are very aggressive looking, as are the STT's... confused. I thought I was set to go on the Mickey Thompsons...
KCCO
Unread 10-14-2014, 05:13 AM   #13
grandboost98
Id highly recommend you stay away from the swampers if youre looking for a decent road tire. My GF has them on her cherokee and its a struggle not to spin them when its raining. Really deep, untouched snow they do alright in but packed snow/ice roads is like a slip and slid. Shes actually looking into tires for it now before we get any snow
They do great off road though, come to think of it, the only time she ever got stuck with them was in the snow lol
89 Jeep Wrangler - 3.5" HD BDS lift and M.O.R.E. HD 5/8" booms on 33s
99 Jeep Cherokee - 2 door, 5" lift on 33" super swampers
72 Chevy Nova - build in progress
98 Pontiac Grand Prix GTP - too many mods to list::SOLD::
grandboost98 is online now   Reply With Quote Quick reply to this message
Unread 10-14-2014, 06:27 AM   #14
ssyj94
Stay away from the swampers if you plan to put many street miles on them. They are loud and wear fast. Like everyone else has said km2's are a good all around tire aswell as mtrk's.
Link locked and ready to rock
Http://www.jeepforum.com/forum/f12/y...lovers-1121183
ssyj94 is offline   Reply With Quote Quick reply to this message
Unread 10-14-2014, 08:08 AM   #15
yj94ne
wow, no mention of Goodyear Duratrac's? Hybrid Mud-A/T. Great in the snow too. Really good tires for New England.
yj94ne is offline   Reply With Quote Quick reply to this message
