Aftermarket Radiators ?? - JeepForum.com
post #1 of 17 Old 04-30-2012, 06:59 AM Thread Starter
NCTinkerer
I picked up the 93 YJ yesterday and got it home. An hour and a half on the Interstate and it ran just fine. When I got home I spent some time going over it and noticed a small leak in the radiator. The radiator looks pretty rough too so I went searching online for a replacement. I saw 1, 2, and 3 row versions. Some were aluminum/plastic and some all aluminum. Prices from 100 - 500. I just want a functional radiator that wont fall apart in a year. What would you guys recommend? Any favorite brands or suppliers? The YJ has a 6 cylinder, 5 speed, no A/C. Thanks.
NCTinkerer is offline
post #2 of 17 Old 04-30-2012, 08:03 AM
pete1991YJ
Most guys just get the aluminum/plastic radiators, about $110 at most parts stores. I prefer the all-metal copper/brass ones, about $300 special order usually. The factory original is copper/brass.
All radiators had a 2-row core on the 5-speed models and 3-row core for the auto trans models. Otherwise they're identical. You could put a 3-row auto trans model in the manual trans jeep for a "hevay-duty" cooling system.
BTW welcome to JF, you've just found one of the best jeep sites anywhere!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #3 of 17 Old 04-30-2012, 08:06 AM
Que89YJ
Radiator Barn is about the cheapest I found. Good rep. too. Stay away from the plastic end caps. The aluminums can use bigger tubes and less lows because of it. They are resistance to the corrosion issues too.
Que89YJ is offline
post #4 of 17 Old 04-30-2012, 11:52 AM Thread Starter
NCTinkerer
I appreciate the help. I've joined other forums in the past when I got into something new. More often than not it seems that the new guys get ignored. Glad to see it's not that way here.
I've been under the dash this morning trying to figure out what 20 years of PO's have done. Lots of loose wires hanging down.
I checked for radiators at the local Auto Parts stores. They are all Aluminum/Plastic with only one row. Is this what guys typically use? Or should I order a 2 row?
post #5 of 17 Old 04-30-2012, 12:00 PM
Que89YJ
Get the single core or dual core aluminum one from the barn. We try and help every one here. It's a great forum and lots of good peeps here.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #6 of 17 Old 04-30-2012, 01:11 PM
gp90
I replaced mine with a two row aluminum, from Leadfoot racing (eBay)
gp90 is offline
post #7 of 17 Old 04-30-2012, 01:45 PM
JWBooth
Absolute CLASSIC!!!!!! "Lots of loose wires hanging down..." Welcome to the club, bro...
-JDub
Please Note: My actual location is a lead box in Sassafras Cove.
-Proud Co-Founding Member of the Dirtbag Brotherhood
-Ringleader of the WhiteTrash Circus.
**LONG LIVE 4-LOW**LONG LIVE 4-LOW**LONG LIVE 4-LOW**
JWBooth is offline
post #8 of 17 Old 04-30-2012, 03:36 PM
pasinbuy
Our original radiator has a plastic top. Get the two row from www.radiatorbarn.com and you will be completely happy. Life warranty and very fast shipping
pasinbuy is offline
post #9 of 17 Old 04-30-2012, 04:36 PM Thread Starter
NCTinkerer
Thanks for the input. I'll order an Aluminum 2 row. I've had a few of the plastic/aluminum radiators in other cars and never felt too sure of them.
post #10 of 17 Old 05-29-2012, 02:37 PM Thread Starter
NCTinkerer
Got a 2 row all metal from JC Whitney. Fits perfectly and is definitely more solid. It is the CSF brand. Thanks for the input. No leaks and temp stays steady. Will know more when it heats up for the summer.
93 YJ, $3500.00: What I've done so far - tires; Soft top & frame; turn signal switch; plugs, cap, rotor & wires; new fluids; mirrors; 2 row aluminum radiator, water pump, hoses & thermostat; brake lines and hoses; Transfer case output seal; rear diff crush sleeve and yoke seal; rear wheel cylinders and shoes;
post #11 of 17 Old 05-29-2012, 02:50 PM
Louie4
Keep us posted. I'm running the standard single core aluminum from A-zone. It's fine on the trail but on the highway it overheats. That tells me it's plugged. I could just swap it out for another since it's got a lifetime warranty. I wonder if they'll do that even though it's not leaking?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #12 of 17 Old 05-29-2012, 04:52 PM Thread Starter
NCTinkerer
Happy to contribute anything I can. Once I get the rear diff back together, I may take a trip to the beach. That will be about 90 minutes at 2-lane highway speeds. If I do, I'll watch the temp.
post #13 of 17 Old 05-29-2012, 06:13 PM
SeanB95YJ
The Ledfoot Racing mentioned above (in case you can't find them on E-bay) is the company that has Champion Radiators.... http://www.championradiators.com/page/400655662
My Neice has their 2-row (currently out of stock, but they had them last week, so probably back soon) on her 4.0 YJ, her boyfriend's son has their 3-row on his 4.7 stroked YJ.
From their experiences, I just ordered their 3-row V8 conversion radiator for my upcoming swap.
Also, an electric fan with shroud/housing (getting rid of your belt driven clutch fan and stock shroud) can go a long way to help with cooling, not to mention freeing up a couple horses currently being robbed by your belt fan
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #14 of 17 Old 06-01-2012, 10:10 AM
Double_DD-s
i second the 3 core aluminum Champion radiator from Leadfoot. $200 and drops right in. Highly recommended by me (whatever that is worth).
Double_DD-s is offline
post #15 of 17 Old 08-01-2012, 04:47 AM Thread Starter
NCTinkerer
We've had quite a few 100+ temp days so far this summer. The new radiator has been good on the highway, around town, or at the beach. Temp gauge climbs to thermostat setting and stays put. I can't say how a single core radiator would do, but I'm glad I spent the extra bucks for the peace of mind.
radiator
radiators iwishihad1 YJ Wrangler Technical Forum 2 04-15-2007 04:20 PM
Radiators?!?!?! RabiDaWise YJ Wrangler Technical Forum 3 05-02-2006 11:22 AM
any good aftermarket radiators? sentry65 TJ Wrangler Technical Forum 7 01-15-2006 02:05 AM
SPI Radiators EDM0656 TJ Wrangler Technical Forum 0 02-09-2004 06:19 AM
Aftermarket Radiators 97sahara TJ Wrangler Technical Forum 5 01-06-2003 11:20 PM
