Aftermarket Gauges - Page 3 - JeepForum.com
post #31 of 33 Old 08-07-2011, 04:39 PM
92 Green YJ
92 Green YJ's Avatar
Originally Posted by piperoo View Post
So you have to paint each gauge with the brush?
I just used the paint bucket set to white. I put up a white set as well as the blue. The blue was the original set I got ahold of.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #32 of 33 Old 08-08-2011, 08:45 AM
EdgyAsHell
I'm gonna say if you can't figure out how to use photoshop enough to use the paintbucket tool you may want to abandon your project, this psd needs alot of cleaning up (for me at least) and things like paper medium & print quality are going to be a factor for me. If you don't know what you are doing they are gonna come out crappy and you don't want that!
In other news, dropped my tank and rewired my fuel gauge, works great now! Going to be doing some crazy black with red detail gauges, I'll post pics when I'm done.
EdgyAsHell is offline
post #33 of 33 Old 08-08-2011, 10:39 AM
Cooper13
I just installed blue leds in my dash Saturday. As, suggested in one of the two write-ups, used the 5 led "bulb" vs the 6. Looking at them in the garage with the doors closed I thought "Uh oh, not bright enough". But actually driving around at night they are the perfect briteness. I even did the snazzy blue/red combo on the tach (blue slowly bleeding into red for safe to gonna-blow-the-engine). The only change I intend to make is using a 6 led for the blue/left side on the tach and a 6 white led on the heater control.
Cooper
Cooper13 is offline
Pictures of installed aftermarket gauges. YJ_eep1189 YJ Wrangler Technical Forum 40 05-12-2017 10:35 AM
Aftermarket gauges marvinb YJ Wrangler Technical Forum 0 01-27-2011 02:45 AM
which size aftermarket gauges?? willyb8 YJ Wrangler Technical Forum 14 11-28-2008 03:07 AM
aftermarket gauges bigman01 TJ Wrangler Technical Forum 3 08-16-2007 06:22 PM
Aftermarket Jeep Gauges? sk187 YJ Wrangler Technical Forum 5 04-11-2004 11:41 AM
