Aftermarket cruise control - JeepForum.com
post #1 of 4 Old 04-22-2002, 09:36 AM Thread Starter
Sunvista
I'm new to this forum and also new to Jeep. I just bought a Wrangler X. It had most of the options I was looking for except I would have liked to have cruise control to get to the mountains. Has anyone installed aftermarket cruise? Recommendations?
'02 Wrangler "X" 4.0 APEX
Sunvista is offline
post #2 of 4 Old 04-22-2002, 04:51 PM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
I installed it on my YJ. I bought a universal, cheap $99 one that works fine. Relitively easy to install. It can be divided into 3 parts: Wiring, vacuum hose connections, and the throtte cable.
Simply spice into the ign. wire, the VVS wire (or is it VSS? either way). Then run the wiring harness up into cab, and mount is accordingly.
Then tap into a vacuum hose. (I chose the PCV hose.
Then hook up to the throttle cable using one of the many different kinds of connections. Use common sense to chose the one that seems to make the most sense.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #3 of 4 Old 04-23-2002, 01:15 AM
93 Blue Demon YJ
I installed one too. I paid $100. installed similar the last post. I have a 4.0, and it stays pinned on your set speed. It would take quite a hill to make it slow down just 1 mph. 2.5 may vary a little more on hills. I would reccomend it if you drive on the highway much. I got a big jump in fuel economy when I use it on the highway.
Richard
'93 YJ 4.0 3" RC lift 15x10 wheels and 32" tires.
93 Blue Demon YJ is offline
post #4 of 4 Old 04-23-2002, 08:30 AM
MusicMaverick
2014 JK Wrangler
Yeah, it does slow on hills, even more with the 31's now. ALso you need a canister for another $10 that the vacuum runs through before going to the servo unit if you have a 2.5
Currently: '14 JKU
OEM or Aftermarket Cruise Control TimBrown TJ Wrangler Technical Forum 17 04-05-2015 08:39 AM
Aftermarket cruise control on LJ? wjordan TJ Wrangler Technical Forum 13 09-07-2007 04:45 PM
Aftermarket Cruise Control djXternal TJ Wrangler Technical Forum 42 10-06-2006 11:54 PM
Cruise control CoriolisSTORM TJ Wrangler Technical Forum 15 07-04-2004 08:22 PM
Aftermarket Cruise Control? Anyone had good luck? BNovak TJ Wrangler Technical Forum 6 06-06-2004 08:50 PM
