01-11-2005, 09:56 PM
#1
After Market Tie Rod For YJ
I have a 95 jeep YJ with a 3.5" superlift. I just installed Terraflex sway bar quick disconnects and noticed that both tie rod joints are shot. I want to replace the stock one with a good after market rod. Does anyone have a suggestion?
01-12-2005, 06:15 AM
#2
Join a 4x4 Club
I just repaired the worn parts whenever I had to address the tie rod.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
01-12-2005, 06:26 AM
#3
Any product made by Moog is a good choice.
01-12-2005, 06:48 AM
#4
Has anyone seen the Canyon Climber Designs system? Go to http://www.phatjeeps.com/ and then select "axle conversions & steering" and then scroll down to the Canyon Climber Designs section. They don't give too much information about the system, but it looks pretty good. I've tried search engines but haven't been able to find this system anywhere else. Feedback from someone that has this system would be great.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
01-12-2005, 07:24 AM
#5
Join a 4x4 Club
That was on a TJ, but it does look nice. I don't like the curved steering link (bent = weaker), but some of the photos showed a straight one.
01-12-2005, 09:46 AM
#6
Actually the top right pic is on a Grand and the bottom left is on a XJ. The bent drag link eliminates the need for a drop pitman and minimized bump steer. I would expect it to be fabricated with heavy wall tubing and it's probably stronger than stock.
01-12-2005, 12:13 PM
#7
Join a 4x4 Club
Do the math, in this case, do a stress analysis. You push at point A and it moves at point B, whether it's straight or bent between the two does not matter to the two points. The visual lets you think you have improved something, but the two parts doing the moving have no clue if the rod is bent or straight. Bump steer? The axle right end moving up or down will be pivoting based upon the location in 3-space of the pitman arm connection, bent or straight again does not matter. The only thing the bent rod does is make it easier to bend more when a 35" tire is jambed on a rock and you keep steering.
01-12-2005, 02:45 PM
#8
Pimp Hand
here is a thread i started on this subject with some information on what i did for my steering.
http://jeepforum.com/forum/showthrea...eering+upgrade
i have since made some changes to my web site so the links have been broken to the pictures. the link below has the pictures on it.
http://pierviews.com/photogallery/je...E/STEERING.htm
i havebeen very happy with the steering upgrade. i used some 1 ton tie rod ends, and flipped the tie rod to the top of the knuckle. this gained apx. 3" on the tie rod to keep it out of the rocks.
if you have any questions or intrest in this, feel free to post on the thread about it
___________________________________________
What is all of this talk of Savvily designed products?
01-12-2005, 03:00 PM
#9
You need to do some more homework...
01-12-2005, 05:24 PM
#10
Join a 4x4 Club
Grim, I made a new thread so others could render an opinion on this, rather than you and I just butting heads.
