After market temp gauge - JeepForum.com
post #1 of 4 Old 02-24-2010, 07:45 AM Thread Starter
standfas
I want to put an aftermarket temp gauge in my Jeep. I bought a universal from Autozone and the sensor doesn't fit into the manifold. It's too big.
Anyone know of a brand of aftermarket temp gauge with a sensor that will fit?
'90 JEEP WRANGLER YJ 2.5L
standfas is offline
post #2 of 4 Old 02-24-2010, 07:57 AM
Xtremjeep
They make brass adapters to make it fit, or put it in a different spot on the block.
Build Thread:
1980 CJ-7 Mall crawler (RIP 2010)
1983 CJ-8 Scrambler Full resto in progress
1988 YJ Fully Built but never Done
Xtremjeep is offline
post #3 of 4 Old 02-24-2010, 09:09 AM Thread Starter
standfas
The one I bought came with brass adapters. But, the actual sensor is bigger than the hole in the manifold.
Are you saying to drill and tap a hole in a different location on the manifold?
standfas is offline
post #4 of 4 Old 02-24-2010, 09:32 AM
crb577
it shouldn't be going into the manifold at all it should be going into the head. so make sure you are trying to put it in the right location.
My autometer sensor fit right into the stock location. or you could use the stock sensor and splice the wires into the new gauge as an alternative.
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
after market gauge install Classicboss1 YJ Wrangler Technical Forum 5 07-13-2009 07:32 AM
After market fuel gauge for 90 4.2L 6 cyl YJ Brinker YJ Wrangler Technical Forum 4 09-03-2008 11:08 AM
after market fuel gauge install Zorm YJ Wrangler Technical Forum 0 08-19-2008 11:16 AM
Temp Gauge RH31379 YJ Wrangler Technical Forum 3 12-04-2007 11:24 AM
Is this temp normal? Temp Gauge Pic !!! Thunderstrike TJ Wrangler Technical Forum 23 06-26-2007 09:01 PM
