After market fuel gauge - JeepForum.com
post #1 of 6 Old 04-20-2013, 08:53 PM Thread Starter
Oper8or
Since I'm replacing the head on the yj I'm updating the gauges too. I'm replacing the stock set with sunpro gauges for now. I have a question about the fuel gauge though. I know its supposed to be 0-90 ohms and I would like to know if anyone has replaced the stock on using a different type. I was planning on using the stock wiring to do it. I was going to just splice the connector coming into the gauge cluster and run the gauge off of it. I found a gauge that is 0-90ohms but I have to order it. Any ideas from here would be appreciated.
Oper8or is offline
post #2 of 6 Old 04-20-2013, 10:30 PM
jokerchief462
Splicing it in will work just fine.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 6 Old 04-20-2013, 10:32 PM Thread Starter
Oper8or
TY very much. All I needed to know.
Oper8or is offline
post #4 of 6 Old 04-21-2013, 08:36 PM Thread Starter
Oper8or
Well I was wrong, that isn't all I need to know. Looking at the manual it states that the WHT is the input and TAN is the sending unit. I've got the ground good and there are not dents in the gas tank. When I hook it up to a ignition hot and the ground to ground it goes to full. When I hook the receiving from the tank to the gauge it stays at full as well. I know the sending unit works because the original gauge worked.
Now, should I run the + to the WHT, the S (send) to the TAN, and the ground BLK to ground? Is that how it supposed to work?
If the WHT is supposed to be power, it aint getting none. I'll have to check the fuse for that one.
Oper8or is offline
post #5 of 6 Old 04-23-2013, 01:44 PM Thread Starter
Oper8or
Got it working. The WHT/wBLK stripe is hot, while the tan(brown) is the send. Its now working correctly. Thanks for the help!
I'll post a pic later of the gauges installed. Nothing fancy, just some sheet metal behind the factory panel.
Oper8or is offline
post #6 of 6 Old 07-27-2013, 07:31 PM
packdog
Which style gauge?
I need to replace my gauge too. The parts store has two types, GM and Ford/Chrysler. Which kind did you use?
*EDIT*. Nevermind, I found it in another post. It uses the GM style which is 0 ohms empty, 90 ohms full. I don't seem to have much luck using the forum search function, but Google seems to always have a link to a thread on this forum!
packdog is offline
