after market 44 - JeepForum.com
post #1 of 15 Old 01-21-2010, 09:31 AM Thread Starter
Towny72
after market 44
Anybody make a aftermarket D44?
Rust, Rust, Rust, and a lil more Rust.....
Towny72 is offline
post #2 of 15 Old 01-21-2010, 09:49 AM
Why J?
Why J?'s Avatar
Rock Crusher does.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #3 of 15 Old 01-21-2010, 09:52 AM
jbolty
jbolty's Avatar
teraflex sells just the center section.
jbolty is offline
post #4 of 15 Old 01-21-2010, 09:59 AM
Axl Jack
Currie Enterprises.
Lets see. Junkyard axle, $200 give or take.
Currie D44.... I think they used to have a price on their website but now all it says is "CALL"
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #5 of 15 Old 01-21-2010, 10:06 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Well, an aftermarket axle all depends on the depth of your pockets unfortunately. There are lots of other options out there.
Do you want front, rear or both?
Could do with a little more info from you bud. What makes you think you need a 44?
What kind of wheeling do you do?
Have you broke any of the stock axle parts?
What size tires you running/want to run?
What gearing do you want to run?
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #6 of 15 Old 01-21-2010, 10:06 AM
leftlanetruckin
XJ on 37's
Never a good sign huh?
post #7 of 15 Old 01-21-2010, 10:30 AM
Axl Jack
Nope, never.
To the OP, if you are talking about the front axle, I say just replace your u-joints with some fresh Spicer ones and wheel the heck out of it until you outgrow it. I plan on putting an Aussie in the front of mine and running 33x10.5 or 34x10.5's in the future. I think (and HOPE) the D30 will hold up. And if it doesn't.... well its time to start searching the junkyards for a D44.
Sometimes people think they need "upgrades" to make them part of the cool crowd. I just carry a spare set of already assembled shaft and bearing that I got for $40 in case I snap one on the trail. Much cheaper than a D44 upgrade at the moment.
Axl Jack is offline
post #8 of 15 Old 01-21-2010, 10:46 AM Thread Starter
Towny72
No more junk yard junk for me. Building a YJ with a friend and we did the 8.8 in my jeep and I was never really happy with the turn out and after the 8.8 i did he wants nothing to do with it. He wants a 44, I can not for the life of my find a 44 that will fit under a yj in a junk yard with in 200 miles of western PA for under $500.... So why pay $500 for a old comanchee axle that needs rebuild, gears, etc?
Towny72 is offline
post #9 of 15 Old 01-21-2010, 11:03 AM
bgredjeep
1987 YJ Wrangler
Solid lists a rear d44 complete axle for $3800. If you can't build a junkyard d44 or 8.8 for that price (hell, buy one, new gears, locker, perches, drop it off at a local shop and have them assemble it for less than that price) then have at it. Thats a lot of money for a d44 rear axle.
bgredjeep is offline
post #10 of 15 Old 01-21-2010, 11:03 AM
leftlanetruckin
XJ on 37's
I have always had good luck with the 8.8 myself. I grab them at $150 each complete.
I would say to start emailing the axle manufacturer's then, but be prepared....$$$$$$$$$$.
His rig, his choice.
Out of curiosity, what was wrong with the 8.8?
Martin
post #11 of 15 Old 01-21-2010, 11:18 AM
bgredjeep
1987 YJ Wrangler
You might also check with the local Jeep dealer. They don't have anything YJ specific that I've seen but they do offer some axle upgrades that would be easy enough to stuff under a YJ.
1
P5155252 Axle, Front Assembly, Dana 44, 2007-09 Jeep
Wrangler, 4.10 Locking Differential, Without Brakes
1
P5155256 Axle, Front Assembly, Dana 44, JK, Modified For TJ
1
P5155084 Axle, Front Assembly, J8, Dana 44, 5 on 5.5 Hub, with
Open Differential
1
P5155087AB Axle, Front Assembly, Stock Power Wagon, 4.56
Ratio, With Locker
1
P5153826AB Axle, Rear Assembly, 2007-09 Jeep Wrangler
Rubicon, 4.10 Ratio, Locking Differential
1
P5155257 Axle, Rear Assembly, Dana 44, JK, Modified For TJ
1
P5155260 Axle, Rear Assembly, Dana 60, J8, 4.10 Limited Slip,
5 x 5.50" and 5 x 5.0" Bolt Pattern, Modified For JK
1
P5155083 Axle, Rear Assembly, J8, Dana 60, 5 on 5.5 Hub,
Limited Slip Differential, Leaf Spring
1
P5155088AB Axle, Rear Assembly, Stock Power Wagon, 4.56
Ratio, With Locker
I like the J8 listings myself.
post #12 of 15 Old 01-21-2010, 12:20 PM Thread Starter
Towny72
It was just one of those one after another deals where by the time it was all said and done the price tag and bloody knuckles had me and him wondering if it was all worth it.
I paid $186 for the axle out of a junk yard with 4:10s
The ruff stuff kit was another $120
After I got it home and cleaned it up I knew I was going to need rotors and brake lines but the calipers were still pushing fluid so I thought they would be ok.
Long of the short after buying the axle and swap kit, finding out the calipers were bad along with everything else I needed for the brakes and a new diff cover the thing ran me close to $850 and I still didn’t put a aussie in it. Oh and I never did get the parking brake to do more then look good for inspection.
Not to mention i run a skinny tire so the narrow wheel base on the 8.8 threw me a curve ball.
Towny72 is offline
post #13 of 15 Old 01-21-2010, 12:48 PM
leftlanetruckin
XJ on 37's
Well, at $800-850, you are still way better off than ordering a custom axle.
Granted, that did get a little out of hand though...
If he is dead set on some other axles, the next best thing would be to scour the used parts sections of pirate for some built/geared 44's etc. There are a couple of axles on there right now that are ready to bolt into a YJ.
Martin
post #14 of 15 Old 01-21-2010, 01:36 PM Thread Starter
Towny72
Your not kidding,
2,995 is the best I found for a built D44....
His budget is not going to be that high for just one axle, he was talking incometax return and get the axles ready for spring. Ill have to price out building one myself.
Towny72 is offline
post #15 of 15 Old 01-21-2010, 01:50 PM
leftlanetruckin
XJ on 37's
If he is pricing axles that need new wheels anyway, you could always try for some JK Rubicon 44's like I have in my junk.
They come up for sale on JKOwners.com pretty regular.
Shouldn't need new brakes etc anyway!
Martin
After market AC?? rockrawling43 TJ Wrangler Technical Forum 3 06-29-2006 01:14 PM
After Market A/C Possible? Flyusaf2002 TJ Wrangler Technical Forum 13 08-08-2005 12:16 AM
After Market A/C eyalh99 TJ Wrangler Technical Forum 1 07-22-2005 04:26 PM
In the market for a YJ IGotADisneyJeep YJ Wrangler Technical Forum 3 07-26-2004 09:48 AM
After market A/C Skoonr TJ Wrangler Technical Forum 1 04-06-2004 11:43 AM
