After engine clean - nasty belt/pulley sound - JeepForum.com
post #1 of 10 Old 04-19-2013, 02:15 PM Thread Starter
Rproject
1987 YJ Wrangler
I went off roading a week or so ago and got the engine completely soaked with heavy mud. Washed down the engine bay, then dried out the plug wires, cap, rotor and distributor and now I've got this nasty sound from one of my belts/pulleys. I *think* it's from the power steering pulley, but I can't be sure. I have hit the belts with A TOUCH of WD-40 and there was no change in the sound. Yes, I hear the minor squeal from one of the belts, but that's not the sound I'm talking about. It's that God awful "rock inside a rolling tire" sound that's got me stumped.
Anybody have any ideas for me on what it could be? The sound was not there before I washed the engine bay.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #2 of 10 Old 04-19-2013, 02:35 PM
UZI4U
The WD-40 is the last thing you want to put on a belt. Sounds like you might be due for a new one anyway. Hose it down again and then try a new belt. Clean the pulleys with some carb cleaner prior to installing to get them and you should be good to go.
MCLMM
UZI4U is offline
post #3 of 10 Old 04-20-2013, 10:14 AM Thread Starter
Rproject
1987 YJ Wrangler
Well, the Wrangler let me know this morning what the problem was. Water pump. Completely took a puke about 1 mile from the house. Thankfully I was heading home instead of away.
As for spraying belts with WD-40, a LITTLE spray is fine. A heavy spray is really bad. My mechanic buddy, who is an ASE master mechanic but very busy and best used for phone support, told me about the trick to spray just a touch on the belts and see if the sound changes. If it does, it's a belt. If it doesn't, it's a pulley. He was right -- again.
1996 White ZJ
Rproject is offline
post #4 of 10 Old 04-20-2013, 01:32 PM
Mark05059
I still wouldnt use wd-40. I would use carb clean or brake clean because they evaporate and dont lubricate. Drive belts and lubrication dont mix at all.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 10 Old 04-20-2013, 01:49 PM
Chrisnvegas
Chrisnvegas's Avatar
There is stuff called "belt dressing". It comes in a spray can and is either a lubricant, or another kind helps belt to grip.
I am not a fan of this though. It only tends to cover up belt problems such as a loose or worn out belt. I have used it in the past when I was in a hurry and needed the belt to shut up for a couple weeks.
Good luck with the water pump.
My Jeep is NOT a Fiat!
Chrisnvegas is offline
post #6 of 10 Old 04-20-2013, 02:21 PM
caoboy
Did it make a squeal that would go away? There is too much other engine noise for me to pinpoint what you are talking about. I have an intermittent squeal when cold that will go away after a few minutes of driving. I'm wondering if I'll find out sooner than later what it is, like you did
caoboy is offline
post #7 of 10 Old 04-20-2013, 03:41 PM Thread Starter
Rproject
1987 YJ Wrangler
Purr little kitty. Purrrrrrrrrrrrrrrrrr
New water pump installed. Weird noises gone.
Hey caoboy - a squeal that goes away shortly after warming up could simply mean that you're low on power steering fluid. Have you checked it lately?
1996 White ZJ
Rproject is offline
post #8 of 10 Old 04-21-2013, 09:43 AM
caoboy
Unfortunately I don't have power steering.
caoboy is offline
post #9 of 10 Old 04-21-2013, 10:19 AM
Mark05059
if you read a can of belt dressing... it says do not use on serpentine belts..
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #10 of 10 Old 04-21-2013, 10:20 AM Thread Starter
Rproject
1987 YJ Wrangler
Luckily I have v-belts.
1996 White ZJ
Rproject is offline
