After brake booster install, brake lights are on??? - JeepForum.com
post #1 of 7 Old 05-16-2009, 11:35 PM Thread Starter
HoustonRenegade
We just finished installing the brake booster for the 93 Renegade, ran into a few bumps such as the D clip on the brake pedal broke, O Riley did have them so we had to rig something up, until I locate one. The main issue is, after installing the new brake booster, the brake lights remain on, any ideas, do I need to adjust the brake light sensor?
Houston Jeep Forum
Josh and Cort 93 Renegade Wrangler
35's GoodYear Wrangler
6 inch Lift,soft top
auto trans,36k on motor, 170k on body,ProComp 9000
HoustonRenegade is offline
post #2 of 7 Old 05-16-2009, 11:36 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The brake lights as in the tail lights, or the brake warning light on the dash?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 7 Old 05-16-2009, 11:40 PM Thread Starter
HoustonRenegade
the tail lights are on all the time with or with out the key on
Houston Jeep Forum
post #4 of 7 Old 05-16-2009, 11:44 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
You need to adjust the brake light switch under the dash, located on the pedal assembly.
Mean Max is offline
post #5 of 7 Old 05-16-2009, 11:59 PM Thread Starter
HoustonRenegade
ok thats what i thought, what causes that?
Houston Jeep Forum
post #6 of 7 Old 05-17-2009, 07:32 AM
Fred007
When I did mine, the hole in the new BB plunger had just a little more metal between the hole and the end. This casued the brake switch to be "on" all the time. I did not see an adjustment, so just ground a little metal off the end of the plunger until the switch worked properly. (did not touch the hole at all, just the end of the plunger)
Fred007 is offline
post #7 of 7 Old 05-17-2009, 07:49 PM Thread Starter
HoustonRenegade
you guys were right, the brake switch needed to be adjusted, the red button was not engaged which was causing the lights to be on. Thanks for your help guys.
Houston Jeep Forum
Replaced Brake Booster - now brake lights stay on Viking TJ Wrangler Technical Forum 4 04-11-2017 06:46 PM
Is my brake booster bad ? mtidwell YJ Wrangler Technical Forum 3 09-19-2008 08:27 PM
No Lights after Stereo Install, (Dash, Parking, Brake), presets dont save either NaptownWrangler YJ Wrangler Technical Forum 3 04-13-2007 07:04 AM
Brake Booster ionakana YJ Wrangler Technical Forum 1 09-28-2006 08:08 AM
Brake Booster?? CarsonKetrowYJ YJ Wrangler Technical Forum 2 07-10-2006 09:07 AM
