Advise of axles - Page 2 - JeepForum.com
post #16 of 19 Old 06-12-2013, 02:39 PM
USMCBuckWild
I beat the stupid out of my jeep. See sig line for details on my rig
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #17 of 19 Old 06-12-2013, 02:44 PM
jagular7
With the larger tires, you not only want to look at axles but brakes too. The little brakes designed for 3000# Jeep on 25's is not going to stop the same with 36" tires on it.
Being a YJ, you can look for axles that have the similar leaf mount spread on the front to be nearly bolt in. Problem is, these will be full size or Wagoneer axles with the diff on the driver's side. If full size, they will SOA setup. Wagoneer will be SUA setup. Then there is the steering and its layout to consider (under/over knuckle or high steer), adapting the better brakes (master/vacuum), ds compatibility, wheel choices, and gear/locker choices.
You can keep the rear a 95-01 8.8 (Explorer/Mountaineer), or if you find a donor both matching axles.
Getting the axles in can take some configuration of spring perches on axles, shock mounts, brake lines (soft/parking), etc.
If you have plans for a v8, then I'd hold off now until you destroy an axle. Then learn from that, replace broken component, and look forward to your driveline upgrade. Jus take the YJ body off and place it on the donor's running frame.
Mike
Jagular
Lnxa, KS
97 TJ SE lifted, locked and rubbered for fun
94 YJ SE stock, 225s, Trail Tested
jagular7 is offline
post #18 of 19 Old 06-17-2013, 06:54 AM
grandboost98
Originally Posted by zeus87gn View Post
What were you doing and how old was the build on it?
I was at a stop light waiting to turn left, went to roll up a little bit and BANG! Its a 4banger on 33s with 225k miles
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #19 of 19 Old 06-17-2013, 08:55 AM
zeus87gn
1987 YJ Wrangler
Damn...
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
