advertised lift vs actual lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > advertised lift vs actual lift
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 03-14-2012, 07:50 AM   #1
shoalsjeep
what is everyone experience on advertised lift vs the actual lift gained? I just installed 2.5'' OME 36Rs (4), plus MORE 5/8 shackles and got 3.75'' of actual lift
shoalsjeep is offline   Reply With Quote
Unread 03-14-2012, 08:26 AM   #2
Zombieislander
It should settle close to the advertised spec in a day or two. Unless your springs were sagging. the 2.5 is amount of lift compared to new factory springs.
Zombieislander is offline   Reply With Quote
Unread 03-14-2012, 08:31 AM   #3
Collin89Sahara
The OME 36R spring that you got (heavy duty spec) net around 3 to 3.5inches of lift, and with your 5/8 booms, the amount of lift that you have sounds about right. As others said, it will settle, but not much more.
Collin89Sahara is offline   Reply With Quote
Unread 03-14-2012, 08:34 AM   #4
dan240
Typically (not always) a lift spring will be taller than advertised and will settle once you drive on them. To really get them settled you'll probably need to get them flexed out in the dirt, not simply drive down the street.
1994 YJ 4.0L 5spd
SOA, TJ Flares, 33" BFG MTs, Ford 8.8, SYE/CV
dan240 is offline   Reply With Quote
Unread 03-14-2012, 08:47 AM   #5
timatoe
With a higher quality spring like OME and BDS you'll likely see higher than advertised and even after they're broke in they'll likely still be a bit more. The flip side of that are springs like RC that will advertise 4" and you may get that for a while then it'll be closer to 2".
timatoe is offline   Reply With Quote
