adjusting the timing??? - JeepForum.com
post #1 of 4 Old 10-14-2009, 08:17 AM Thread Starter
bjbrowder
I have searched and read how to adjust the timing on here for days and I cant get a clear answer on how to plug the vac line. Please correct me if im wrong.
Warm the engine up, unplug the vac line from the dist and plug it. So, do you leave the dist vac port open??? Or plug it to. Basicly, do you plug the port on the dist, or leave it open and plug the vac line going to the carb?
Also, everyone says something differnt on engine speed, 650,750, 850, or 1600 rpms. What actuall RPMs do I need to set it at?? The engine is an 1988 258 with 170K on it, team rushed, nuttered, 32/36 Weber, and holley Fuel pressured.
bjbrowder is offline
post #2 of 4 Old 10-14-2009, 08:35 AM
xxxflhrci
xxxflhrci's Avatar
Plug it at the advance. Set it at 1600 rpm.
xxxflhrci is offline
post #3 of 4 Old 10-14-2009, 08:41 AM
spshultz
1987 YJ Wrangler
Plug the vacuum hose that runs back to the carb. I use a golf tee. The port on the vacuum advance at the distributor can be left unplugged because it creates no vacuum.
When Nuttered, timing is adjusted at idle speed (650 - 700). This is the way I do it and have had no issues. And I've played with the timing a lot to find that perfect spot.
If not Nuttered then it has to be timed at 1600 RPM along with disconnecting a few things (I don't remember what they were).
And at 1600 RPM the weights should be starting to move out. At idle the weights aren't out yet. So you can time it at 1600 or idle.
spshultz is offline
post #4 of 4 Old 10-14-2009, 09:14 AM Thread Starter
bjbrowder
Thanks for explaining that, i couldnt figure it out. I will try that tonight and set it at about 8 or 9 degs.
Timing help! Replaced timing chain now I can't get the timing right. yjcrawlr YJ Wrangler Technical Forum 29 04-09-2010 08:36 AM
HELP....Adjusting the IAC..?? davenay67 TJ Wrangler Technical Forum 2 07-10-2008 09:25 PM
adjusting the timing belt losfreddy TJ Wrangler Technical Forum 7 04-23-2006 12:07 AM
Adjusting IPF H4s MCanavan TJ Wrangler Technical Forum 4 04-07-2006 09:35 AM
Adjusting the TPS Phantom5oh TJ Wrangler Technical Forum 4 10-26-2002 07:02 AM
