Adjusting rear drums - JeepForum.com
post #1 of 25 Old 11-14-2012, 09:24 AM Thread Starter
tonymartin
So I went to get the car road tested today for registration and it was so close to passing, only for the fact that the rear left brake is not as strong as the rear right. It was noticeable when I was watching as the left wheel stopped about 2 seconds after the right.
What I need to know is, how do I adjust the drums to get them a little tighter? I know the shoes are OK (or should be) as they were only changed about 1200km's ago. I've never had to work with drums before, so an idiots guide would be highly appreciated.
Thanks
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
post #2 of 25 Old 11-14-2012, 10:32 AM
booboowv77
It is pretty simple there is a gear or a sprocket looking piece towards the bottom of the drum brakes. you just turn it to adjust them in or out to give you more braking. It is pretty much being pointed to in the pic, yours may not look exactly the same, i think the picture is from a TJ. But same concept.
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #3 of 25 Old 11-14-2012, 10:54 AM
EABiker
You can access this without removing the drum through a small opening on the bottom rear of the backing plate. It's a punch-out; if it has not been punched out before, you will need to remove your drum as you don't want this piece of metal running around inside your brakes! You can adjust the star wheel with a screwdriver by levering it against the teeth of the wheel. Spin the tire while you do this until you hear or feel the shoe contact the drum.
EABiker is offline
post #4 of 25 Old 11-14-2012, 10:40 PM Thread Starter
tonymartin
OK, so if I'm lying under the rig and looking directly at the backing plate of the rear left set up would I turn the sprocket up or down to tighten it? I presume it would be up but I'm not sure.
Sorry if it's a stupid question, I just wanna get this done right first time as I need to get the rig registered ASAP as we're selling our DD and have no other motor!
post #5 of 25 Old 11-14-2012, 11:52 PM
Dake
Dake's Avatar
It is at the bottom back side it will have a rubber plug in it. Take a stubby flat blade screwdriver to turn the gear or a sprocket.
Dake is offline
post #6 of 25 Old 11-15-2012, 04:34 AM Thread Starter
tonymartin
I got that part Dake, what I need to know now is, which way do I turn the star wheel, up or down?
post #7 of 25 Old 11-15-2012, 04:45 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Stick the screwdriver into the slot & engage the top of the adjuster, then rotate the screwdriver to roll the top of the adjuster down to the bottom. It should produce a clicking noise.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #8 of 25 Old 11-15-2012, 05:08 AM Thread Starter
tonymartin
Thanks Max, exactly what I was looking for. Whilst you here, I have heard that you can swap the master cylinder with one from a 74-78 ford/lincoln/mercury. Being in the UAE it may be hard to find one from that type model. Any other master cylinders to add which will give the brakes a bit more pressure with a bit less pedal?
Thanks
post #9 of 25 Old 11-15-2012, 06:54 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks
You're welcome.
I usually use one from an E-350 Ford van. I can't remember the year & part number, but I'll look it up.
It's not completely "plug & play" but the modifications are easily done.
Max
Mean Max is offline
post #10 of 25 Old 11-15-2012, 07:00 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Read here.
http://www.michiganwheelers.com/foru...ad.php?t=17922
Max
Mean Max is offline
post #11 of 25 Old 11-15-2012, 07:22 PM Thread Starter
tonymartin
Thanks for the link Max, it looks simple enough. I noticed that one post says it will only improve braking if you have higher capacity calipers. Is that true as I though more capacity/pressure would mean more stopping power?
Thanks again bud, always great info!
post #12 of 25 Old 11-15-2012, 07:24 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
It will make a very good increase in power, even with stock calipers.
Max
Mean Max is offline
post #13 of 25 Old 11-16-2012, 02:11 AM Thread Starter
tonymartin
OK great, thanks Max. I'll look into getting one shipped over from rockauto.
Cheers
post #14 of 25 Old 12-02-2012, 10:57 PM Thread Starter
tonymartin
Well I adjusted the drums and there was a noticeable difference in braking power. Strange how they've come some far out of adjustment in only a year/1100 Km's (I barely drove it last year). I did notice that the passenger side didn't click which leads me to believe that the locking arm on the star wheel is loose/broken.
Anyway, adjusting the drums also pretty much relieved one other problem I seemed to not be able to find. I have a clicking noise coming from the rear end and was having no luck finding it. Once I adjusted the drums it seemed to get much better. Hopefully that is the solution, and not just something being so worn that it isn't clicking anymore!
I also found a good E350 MC from rockauto which I will be ordering this week, hopefully, and getting fitted ASAP!
Thanks guys
post #15 of 25 Old 01-20-2013, 09:50 PM Thread Starter
tonymartin
So, I went last night again to get it registered and it is still showing as the rear left brake is not as strong as the right. The tech there suggested that the wheel cylinder might be on it's way out as they tested it three times and got different results each time. All of which were showing the brakes not as strong as they should be. Now I got a quote for a full brake requild kit minus the drums and a wheel cylinder for each side and it comes to around US$160 with shipping. Would I be better getting the rebuild kit or trying to find a good condition set of disks and hardware from a ZJ instead?
It would probably cost me the same in parts from the JY as it would for the new parts from Q-tec, but as I don't have a place to work on the rig other than the Embassy compound which I work in I don't think I would be able to swap in the disks due to having to remove the rear axle shafts to get the backing plates swapped over.
Do all YJ's have a 35C or are some non-c clip models, and if so, how would I know without pulling the diff cover?
Thanks
