Adjusting the idle on a 1988 YJ - JeepForum.com
post #1 of 4 Old 04-08-2010, 10:25 AM Thread Starter
Ed_Lorentz
2007 KJ Liberty
Does anyone know how to do this? I had a couple of people look at it but can't seem to find out how to. I need to increase it because it will stall out if I let it sit still without reving the engine.
Thanks
Ed
Ed_Lorentz is offline
post #2 of 4 Old 04-08-2010, 11:14 AM
YJMonster
Which motor.
2000 xj 4.5 Rubicon Express extreme duty(sold)
1988 yj 2.5 RC lift, 1/2 boom shackles- My baby
YJMonster is offline
post #3 of 4 Old 04-08-2010, 11:41 AM Thread Starter
Ed_Lorentz
2007 KJ Liberty
Its the four cylinder.
post #4 of 4 Old 04-08-2010, 11:57 AM
RebuildRookie
The ECU automaticaly adjust the idle. The only thing that can be done is to adjust the screw on the throttle plate, but I wouldnt recommend doing that to much, being that it is set from the factory. Of course PO's tend to mess some things up if they dont understand what they are doing.
What is the idle at when at a stand still in neutral?
Also, your Idle actuator motor might be bad. It moves the screw ,i was telling you about, in and out to adjust the idle at start up and at normal idle when operating.
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
Adjusting Idle? cthames YJ Wrangler Technical Forum 1 04-20-2008 02:35 PM
adjusting idle on 2.5 TBI 89 YJ possible? Big-n-Broke-YJ YJ Wrangler Technical Forum 4 08-13-2006 03:57 PM
Adjusting Idle? kc7hyp YJ Wrangler Technical Forum 0 12-06-2005 04:42 PM
Adjusting idle rpm cygnus3978 TJ Wrangler Technical Forum 2 10-15-2004 06:04 PM
Adjusting Idle Screws smok3y YJ Wrangler Technical Forum 9 06-18-2003 05:04 AM
