adjust carb for altitude? - JeepForum.com
post #1 of 2 Old 12-20-2001, 12:15 PM Thread Starter
CF
I posted this in the General forum but didn't get a response. Someone must have some advice on this. I mean isn't the Rubicon up in the Tahoe area?
Iíll be going up to Tahoe. Itís at 8200 ft. Iíll coming from the SF Peninsula at sea level. Will I be too rich at that altitude? Should I adjust the air/fuel ratio when I get up there? Iíve got a carbureted 258.
94' XJ - 3"lift, 31s
CF is offline
post #2 of 2 Old 12-20-2001, 07:11 PM
pokey
There is a large metel loop on the end of your loom on the riders side. I think the wire is black. It's just hanging there probably in front of your battery some place. Just take it to the block or whatever to ground. When you do this it makes the 258 think it's at altitude and it will run great up there. Don't hook it up until you get there of course. you could run it on a switch in the cab to ground it whenever you wish if you go high very aften. Do it, it works and it's the only mod you'll need for altitude.
Bud
pokey is offline
altitude changes lovelegos18 TJ Wrangler Technical Forum 3 02-26-2008 11:37 PM
High altitude trailsnail YJ Wrangler Technical Forum 7 10-22-2007 09:37 AM
Altitude Faramir66103 TJ Wrangler Technical Forum 11 06-05-2006 10:11 PM
How to adjust a carb oct7brian YJ Wrangler Technical Forum 4 03-07-2005 02:50 PM
How to Adjust Throttle Body/Carb??? 2ksportNY YJ Wrangler Technical Forum 3 11-19-2003 08:16 AM
