Adding Rubicon 1505 Brake Line Extensions - Help - JeepForum.com
 2Likes
  • 1 Post By timatoe
  • 1 Post By TSEJEEPERS
post #1 of 3 Old 09-26-2017, 10:20 AM Thread Starter
Dmaiorano123
Need some pictures of YJ's with the Rubicon Express front brake line extensions (1505). I recently lifted the YJ with the Rubicon Express 2.5" Standard lift. Tried to install brake line extensions but they really look unsafe. They are not far from the Sway Bar quick releases and shocks. I reconnected the original for now. Hoping to see what others have done with these extensions. Please send pictures.
Dmaiorano123 is offline
post #2 of 3 Old 09-26-2017, 01:57 PM
timatoe
timatoe's Avatar
There's not much to it, they connect to the stock hardline and hang down the side of the frame and go to the softline. I don't particularly like them. It's just as easy to move the stock line to the bottom of the frame rail = $0.
Dmaiorano123 likes this.
timatoe is offline
post #3 of 3 Old 09-26-2017, 02:01 PM
TSEJEEPERS
You can use springs to keep them out of the way.
Do not attach them to the shock. I did this and rubbed a hole in them.
Like this.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
brake line , YJ
