adding brake fluid - JeepForum.com
post #1 of 3 Old 10-31-2009, 12:53 PM Thread Starter
driftbandito
adding brake fluid
This may be a bit of a dumb question, but do i add brake fluid to both sides of the master cylinder and roughly how high should i fill it. thanks
driftbandito is offline
post #2 of 3 Old 10-31-2009, 01:02 PM
yjmoose
If you are needing to add a lot of brake fluid, on MY jeep it usually means that the cylinder's/pistons are pushed all the way out, and it would be a good time to check the amount of brake pads you have left. If the pads are all good, you might have a leak which is a very common problem with our older jeeps. If you are needing to add brake fluid frequently I would suspect a leak. Check the Hard lines, as these like to rust out.
Now, to actually answer your questions, Yes, you would add fluid to both sides of the reservoir, The small side to the front is for your rear brakes, and the larger side to the rear is actually for your front brakes. You would add fluid to the top, being careful not to spill it out of the top, (maybe about 1/4 of an inch from the top) and then push the gasket that is in the top back into itself until its flat. Then reinstall the cap.
Hope that helps
Yjmoose
yjmoose is offline
post #3 of 3 Old 10-31-2009, 01:17 PM
MJMPC
Look at the back side of your wheels and see if it looks wet/damp if it does you have a leak . Also look around the master cyclinder and inside the jeep where the brake rod goes through the firewall .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
Adding differential fluid. Bigsam TJ Wrangler Technical Forum 3 04-09-2008 04:31 PM
adding fluid to an ax-5 sasquachYJ YJ Wrangler Technical Forum 3 03-14-2008 05:30 AM
Adding fluid to diff keithert TJ Wrangler Technical Forum 17 04-29-2007 01:47 PM
Adding tranny fluid bbunn1 YJ Wrangler Technical Forum 6 10-26-2005 10:37 PM
Adding fluid to transfer case odanny TJ Wrangler Technical Forum 4 08-09-2004 09:32 AM
