add a leaf question - JeepForum.com
post #1 of 3 Old 01-24-2002, 07:59 AM Thread Starter
GREGDOG95YJ
GREGDOG95YJ's Avatar
add a leaf question
My next step I do is add a leafs and I would like to know everybody that has used them what there opinion is? I have narrowed down my choices to the ranchos & the bds add a leafs. There is also some add a leafs made by a company called McCoy Brothers that are sold by www.macromotive.com but, I need more info on them before I take them in to consideration. Thanks for the help.
Jason Gregory
95 yj Rio Grande 2.5L
31" BFG MUDS, 1"BL,2" homemade spring lift, 150W KC'S, KN Filter, both air restricters gone, track bars gone, quick discos, & high flow cat
"just like all addicts my need to satisfy my addiction far exceeds my wallet!!"
GREGDOG95YJ is offline
post #2 of 3 Old 01-25-2002, 12:29 PM
NappyYJ
NappyYJ's Avatar
I don't recommend add-a-leafs. When I first bought my 91 YJ I got them put on it was this big ole process. First they have to take the spring pack apart then install the add-a-leaf then put it back together. You would save time and money if you just a bought 2in lift. Plus the ride is better the add-a-leaf makes for a terrible ride. I would only do an add-a-leaf if I were doing a Spring Over Axle Lift but I won't get into that.
91YJ 4banger, 3in BDS lift, quick disconnects, Revolver Shackles, 4:56 gears, 33in thornbirds, Catback exhaust, Turbo City air intake, Air Aid throttle body spacer, Lockers coming soon!!!
NappyYJ is offline
post #3 of 3 Old 01-25-2002, 12:34 PM
osburn
osburn's Avatar
The only add-a-leaf I've had any success with is the Rancho full length. Granted, an add-a-leaf can make for a stiffer ride. But for about $150, it makes a decent 2" lift that's much better performing than a shackle or body lift. Yes, you do have to open up the packs, put in the add-a-leaf and put the pack back together. Not really a big deal. Have either a c-clamp or vise available and a big pry bar for the spring clamps and it's really not a big job.
Matt Osburn
Score 1032
osburn is offline
rear leaf question bigsquat YJ Wrangler Technical Forum 3 12-12-2008 12:24 AM
add a leaf question 90sahara YJ Wrangler Technical Forum 2 06-24-2008 08:05 PM
Leaf spring question? NEPhillyJeep YJ Wrangler Technical Forum 4 09-23-2007 07:36 PM
lift/leaf question RLSFANS1 YJ Wrangler Technical Forum 3 04-26-2006 07:39 PM
Add a leaf question ImRaptor YJ Wrangler Technical Forum 8 04-24-2006 08:36 PM
