Add-a-Leaf - JeepForum.com
post #1 of 4 Old 12-04-2001, 02:11 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Add-a-Leaf
allright i have a few questions???
. Are add a leafs good??
. Can i add more than one??
. will i get more lift??
. and will this affect a jeep with slip yoke a 4inch lift and 3/4 elliptical suspension???
Thanks, Shawn
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 4 Old 12-04-2001, 08:27 PM
osburn
osburn's Avatar
Are they good? That depends on the goal. If you're looking to improve the ride, absolutely not. If you're looking for a little more lift, then yes, you'll get about 2".
Procomps suck though. Get a full length add-a-leaf if you get one.
They're designed to curve the stock spring to a slight curve to gain 2". I really doubt they'd do anything but maybe make a 4" pack stiffer.
Sure you can stack more than one. Dunno what you'd gain, but no reason you couldn't do it assuming your center pins and u-bolts are long enough. If you're SUA, it does mean less clearance under the pack though.
Matt Osburn
Score 1032
osburn is offline
post #3 of 4 Old 12-04-2001, 11:46 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Less clearance under the pack???
Hmmm... I am not sure what exactly that means... where would i get these straight add a leafs and longer ubolts and center pins??
Thanks Matt,
Shawn
1998 TJ
post #4 of 4 Old 12-05-2001, 08:17 AM
osburn
osburn's Avatar
On an SUA setup, the thicker the pack (an add-a-leaf would add to the thickness) the less clearance between the ground and the bottom leaf.
Just about any 4x4 shop should be able to get the full length add-a-leaf for you. I'd recommend Rancho.
The center pins come with the add-a-leaf. Your current u-bolts might be long enough. But it's always a good idea to get new u-bolts since they stretch and commonly have torn up threads. You might not need new ones, but having them means you won't have to go find them if you need them half way into the job. Better to be looking at them, then for them.
Matt Osburn
Score 1032
osburn is offline
Add-A-Leaf to Leaf springs qadhafi YJ Wrangler Technical Forum 6 02-25-2011 02:40 PM
5 Leaf Vs. 6 Leaf YJ springs for SOA application yjcrawler YJ Wrangler Technical Forum 5 11-21-2009 02:27 PM
bad leaf springs should i replace or help leaf? Mohooku YJ Wrangler Technical Forum 3 10-07-2009 08:28 PM
Removing a leaf from leaf springs jonlb YJ Wrangler Technical Forum 14 04-12-2009 12:59 PM
removing 1 leaf from leaf springs skipilot YJ Wrangler Technical Forum 2 02-25-2009 01:37 AM
