Quantcast Add 5 gallons to your YJ's gas tank in less then 1/2 hour?? - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Add 5 gallons to your YJ's gas tank in less then 1/2 hour??
Old 08-12-2009, 09:57 AM   #106
hanshunter
hanshunter's Avatar
Originally Posted by BitterOso View Post
I've done this mod on my 95 YJ (profile has all mods, nothing new since I increased tank capacity) without dropping my tank. I followed the instructions in the previous thread. The only thing I would add to the commentary here is, be careful when pulling the tube out of the tank. I ended up with a nasty cut on my wrist when my pliers slipped off the tube and my arm crashed into the edge of the tub (where the plastic gas cap housing was removed). I could easily have used 8-10 stitches. If I did it over again, I would have hung a towel around the exposed edges of the sheet metal at the tub.
I've been very happy with mod, though.
HA! Sounds hella familiar! BUT!!!! Went through all that and the the MOD had already been done! I had only had my 95' for a month or so when I read this write-up and had never run my tank empty and refueled it to check the capacity. I was just way to excited to get 5 extra gallons! Would never had thought the PO would think of doing this!
hanshunter is offline   Reply With Quote
Old 08-12-2009, 06:11 PM   #107
hotrodhawkes
Easiest mod i have ever done that makes such a difference. any idiot can do it. thanks to the genius who discovered this!
hotrodhawkes is offline   Reply With Quote
Old 08-14-2009, 05:08 PM   #108
StreetBMXer88
did it the other day, literally takes less than 15 minutes
StreetBMXer88 is offline   Reply With Quote
Old 07-09-2010, 08:38 PM   #109
Bnabb
Did this today but the inner hose on mine was only about 6-7 inches long. I just took the whole tube out and threw it away. I could only get about 13.5 gallons before so I'll be looking forward to filling up next time. Whole mod took about 20 min but half of it was taking the stupid tube out
Bnabb is offline   Reply With Quote
Old 07-09-2010, 09:19 PM   #110
JMAC90YJ
JMAC90YJ's Avatar
About 2 years ago, before I knew about JeepForum.com, I purchased a new polypropolene 15gal gas tank from JC Whitney for my 1990 4banger. I had my local garage install it for me reusing the old sending unit ans the rest of the parts. What is the chance that a 15gal replacement tank with this mod will get me 20 gallons of gas?
JMAC90YJ is offline   Reply With Quote
Old 07-09-2010, 09:57 PM   #111
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Sorry, '91 through '95 only. Read post #2 on this 2 1/2 year old thread.
Wrangler YJ Gas Tank Modification 15 to 20 Gallons
White '94 YJ 2.5L 5 speed, 33" BFGs MTs, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio
Member #94 White Jeep Club
My Jeep
'89 XJ Laredo Bone Stock
KB6NQT
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline   Reply With Quote
Old 07-10-2010, 11:23 AM   #112
Zangief
so what i understand is for us 90 YJ guys this is not an option? Is that right?
Zangief is offline   Reply With Quote
Old 07-10-2010, 03:40 PM   #113
AZoriginal
Junior Member
AZoriginal's Avatar
Correct. Not an option for your 90.
Never, Never, Never Give Up
Winston Churchill
AZoriginal is offline   Reply With Quote
Old 07-10-2010, 06:31 PM   #114
Mr-Rock
Mr-Rock's Avatar
My '89 has a Poly tank that i can't get more than 12 gallons in. did they make two different poly tanks that year?
'89, 4.2, NUTTERED, Team Rush, 4" lift, 1"BL, 1"MML, Flat belly skid, SYE, CV Driveshaft,
35 x 12.50s, XRC8, 150w KC's, Herculined, Tauras Elec Fan, Dual Batteries, 1" shackles & Soft Top for the summer, TJ flares.
Mr-Rock is offline   Reply With Quote
Old 07-10-2010, 07:25 PM   #115
danman33
Thanks to those that got this post bumped back to the top.....I had never seen it before....Just did it and only took a few....5 more gallons.....Awesome.
danman33 is offline   Reply With Quote
Old 07-10-2010, 07:49 PM   #116
Jeremy93yj
I did this last week while messing with my sending unit. Since my truck has the fuel pump access door mod, I went in the other way; I reached into the tank through the sending unit hole, felt for the offending hose, gave it one good yank, and Presto! 5 more gallons!
Jeremy93yj is offline   Reply With Quote
Old 07-10-2010, 08:16 PM   #117
Red_92_YJ
well i am new to the forum and i had never heard about this mod before i am so happy it got bumped because i go from my house to college a few times a year and its around 300 miles so not having to fill up ever 175 miles would be nice but i have never put more than 10.5 gal in my tank and i have had it below empty. will this still work on my tank i have a 92 YJ or do i just have a smaller tank?
Red_92_YJ is offline   Reply With Quote
Old 07-10-2010, 08:22 PM   #118
Jeremy93yj
I believe this works on 91-95 trucks, so you're gravy!
Old 07-10-2010, 08:29 PM   #119
Red_92_YJ
what do u mean by trucks?
Old 07-10-2010, 08:37 PM   #120
Jeremy93yj
YJs
Glock Forum
