Quantcast Add 5 gallons to your YJ's gas tank in less then 1/2 hour?? - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Add 5 gallons to your YJ's gas tank in less then 1/2 hour??
Old 03-08-2009, 10:42 AM   #76
jakechristina
Replaced my Fuel pump the other day and did this mod while I was at it. after i replaced the tank was able to get 19.8 gals of fuel in there.
jakechristina is offline   Reply With Quote
Old 03-08-2009, 12:32 PM   #77
plumber1
OK what was this so called tube installed for, what does it do. And what happens by shorting it. I do know from experience that I run out of gas at 1/4 on the gauge. And if I can 20 gallons I could keep from mounting a 5 gallon can on the back.
Not here for a long time, were here for a good time
plumber1 is offline   Reply With Quote
Old 03-08-2009, 02:50 PM   #78
Alacran
One of the mysteries of life. Doesn't really do anything other than cut down on the amount of gas you can put in the tank.
Alacran is offline   Reply With Quote
Old 03-14-2009, 01:55 AM   #79
PhilipJ
tactical recon snow dog
PhilipJ's Avatar
It was originally an 'upgrade option' from Chrysler. So basically, $$$.
The tube sticks down into the tank so when the fuel line reaches the end of it, the pump senses a change in pressure and shuts off automatically. Also the more the pump is open, the more splashback will occur and may shut off early as fuel bubbles and sloshes around into the tube before the tank is actually full. By shortening or removing it, more fuel gets into the tank before it hits the tube (or filling neck if you yanked it out completely).
PhilipJ is offline   Reply With Quote
Old 03-31-2009, 12:26 AM   #80
miwoodar
I'm glad I decided to look up the '20 gallon tank' mod to see what it was. Here's a bump for the thread. Time to go check my hose clamp. Hopefully it is in an available position so I won't have to drop the tank.
miwoodar is offline   Reply With Quote
Old 06-12-2009, 08:37 AM   #81
dswi
Is there any chance of the fuel pump electrical connections (inside of the tank) getting gas on them???
Or actually...Is this a problem (not to sound too stpid...but, fuel plus spark = BIG BANG!).
Or is it designed for this?
dswi is offline   Reply With Quote
Old 06-12-2009, 09:58 AM   #82
jeepercreeper77
jeepercreeper77's Avatar
it's desired to be submerged in gas.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000
jeepercreeper77 is offline   Reply With Quote
Old 06-12-2009, 10:32 AM   #83
jaycal3
Hey guys, I live in CT where the Emissions laws are real tough - any known Emissions issues when doing this mod? I have been told there may be...
'04 BMW 545i - Black w/Auburn Interior - MTEC V3.0 AE's - Black and white roundels - Clear LED Sidemarkers - New Conti ExtremeContact DWS's - Charcoal Filter Delete
'93 Jeep YJ - 6 cyl 4.0 - 3.5" BDS - 1" Prothane BL - 33" meats - custom black and tan dash - glow gauges - SpiderTrax 1.25" spacers - Rampage Recovery bumper with swing
jaycal3 is offline   Reply With Quote
Old 06-12-2009, 10:59 AM   #84
frhrwa
frhrwa's Avatar
This makes working much easier since there are less gas fumes in the tank and the workarea.
the link above states this!.. WRONG.. if you empty your tank, you'll have MORE fumes.. a quarter tank of gas will explode with any spark or flame, a full tank of gas will not.. it may ignite, but will not explode.. so be leary of emptying your tank and feeling secure with the supposedly non-existent fumes..
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his jeep.
frhrwa is offline   Reply With Quote
Old 06-12-2009, 11:04 AM   #85
befumo
Originally Posted by sstaurus View Post
Only 91+ as far as I know, 87-90 there were actually 2 different tanks.
Yeah i thought i had a 15 gallon tank than i decided to actually fill it up.. and added like 18 gallons..
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
befumo is offline   Reply With Quote
Old 06-12-2009, 11:23 AM   #86
gkainz
I disagree that you'll have more fumes. You're not increasing your tank's physical internal dimensions or capacity. You're simply modifying the fill and return tubes to allow more of the tank's original capacity to be used. You will have the same amount of fumes in the tank regardless of this mod.
gkainz is offline   Reply With Quote
Old 06-12-2009, 06:03 PM   #87
Dhofstet
He means if you plan on emptying your tank before this mod. If you empty your tank you will have more fumes than if you left it full or half full..
Spineless, and mindless, You flex your muscles but not your F***ing head..
Dhofstet is offline   Reply With Quote
Old 06-13-2009, 02:42 PM   #88
57plymouth
Originally Posted by papa_panda View Post
Has anybody been able to do this w/o dropping the tank on a Jeep with stock suspension?
Mine has no enhancements- yet...
Yes. No problem at all. I used a very long set of needle nose pliers. They are about 10" long. They were able to grab the tube from below and pull it out no problem.
Of course, the tube in mine was only three inches long. Does that mean the tank in my Jeep is a 15 gallon maximum capacity tank? I know the previous owner pulled it out to replace the fuel pump, but I don't think he replaced the tank. Also, my guage never reads more than 3/4. What's up with that?
Virtus Junxit Mors Non Separabit
57plymouth is offline   Reply With Quote
Old 06-13-2009, 07:56 PM   #89
dswi
Also, my gauge never reads more than 3/4. What's up with that?
There is a small pan in the bottom of the gas tank that might have broken loose....I know when I was changing my fuel pump the other day (I only had to buy the 2" piece of hose that was deteriorated instead of the whole pump) I did the mod to the gas tank and removed the small "pan" under the fuel pump that had broken loose...Others have done this and it has been successful...
I believe it was originally put there to not run out of gas on a hill or something....Mine seems to be fine without it.
Your fuel gauge float might be stuck on that plastic POS in the bottom of the tank.
Old 06-13-2009, 11:46 PM   #90
95jy
thanks man great write up
95jy is offline   Reply With Quote
Glock Forum
