Add 5 gallons to your YJ's gas tank in less then 1/2 hour??
#31 | ||
King of the hill
NFSS - 15 Gallon Fuel Tank
Jeep garage: 2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0 1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold 1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac 2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud? |
#32 |
What are you talking about? My gas gauge is very accurate. When it hits half of a tank it means your empty!!! LOL.
"Hey, hold my beer and watch this...I can make that" |
#33 |
After reading this post i decided to give it a try, took about a half hour, 15 min. just to remove the tube. i'll be filling up tomorrow so we'll see how much it takes.
#34 |
I'm lucky if I can get 12 gallons in mine...
Is there a way to correct or fix the sending unit? Mine seems to be fairly accurate, but I REALLY want to do this mod as I can't even get close to 15 gallons!
US Army combat vet Armed Forces Jeeps Member #125 Red Jeep Club Member #251 In the Portland/Vancouver area? Check 'em out! Piston's Wild Motorsports Club Click here for 2.5L AX5 to AX15 swap |
#35 |
If your sure that your sending unit is accurate I would just go ahead and do the mod. Just be aware that the first 1/4 of a tank of gas will read full. You can always replace the sending unit but it's alot of work and expense and the sending unit doesn't change how much gas you get out of a tank.
#36 | |
tactical recon snow dog
There's really only 2 tough spots, 1 if you're smart... - Lowering/raising the tank with fuel in it. Try to siphon it out first, even a gallon sloshing around in there makes that thing hard to finesse between the leaf springs. - Loosening the hose clamps. It's so cramped in there, you might need a nub of a screwdriver to loosen them. Especially if the heads are pointed toward the wheel well like mine were. I ended up drilling a small hole in the bed right behind the wheel well and using a really long, skinny flathead to do mine. If you are lucky, they will be pointed towards the rear quarter-panel instead. If not, I hope you know a midget.
'Are we done yet?' build |
#37 |
Has anybody been able to do this w/o dropping the tank on a Jeep with stock suspension?
Mine has no enhancements- yet...
'92 White YJ w/Grey soft top, 2.5L from '97 TJ, original 5-Speed, Silver Grizzly Alloy rims from 2001 TJ with Goodyear Wrangler GS-A 225/75R15 Marine Corps Jeep Club Member #7 White Jeep Club Member #350 |
#38 |
Um...so now instead of costing $40 to fill up it will be $50.
"Jeeps are the equivalent of barbies for men."-JaikYJ 1996 Cherokee XJ, All stock except for a Flow Master exhaust.........for now. He He. http://www.cityprofile.com/forum/tucson/ |
#39 | ||
Those who are worried about the sending unit, after you burn off the first 6-7 gallons of gas the gauge will come down and you will have around 13 gallons with the needle just below Full. Half tank around 7 gallons and when it gets close to empty it really is close to empty. A proper sending unit is definately not worth the money or hastle.
1995 YJ on 40's * 2002 TJ on 37's * 2003 TJ on 33's * 2011 WK Larado X w Hemi |
#40 |
I did mine without dropping the tank. It's tight but doable and I don't have the smallest hands in the world. Just take your time and don't get frustrated. The hardest part for me also was removing the inner vent tube.
#41 |
Yep. It took me longer to get that tube out than to do the rest of the job.
You can't teach an old dogma new tricks. |
#42 |
Did yours have a stock suspension at the time? Most of those that have posted I see have some kind of lift, which I'm sure really helps... I'm just wondering....
#43 | |
Actually I did do mine without dropping the tank, I forgot -- that's why it was such a ***** with the hose clamps. At that point I had just cut the tube down to 2" so I wouldn't overfill and put it back in. It wasn't until I had to drop the tank to replace the fuel pump that I just took the whole tube out (it always overfilled anyway).
#44 |
I saw your thread yesterday and did the conversion today. Thanks, it was an easy job.
And to think I almost bought a new 20gal tank. |
#45 |
Mine has the stock suspension with 31" wheels. Biggest problem I had with the vent tube was trying to find it, it is a tight fit and at first I wasn't sure it was there.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
