Add 5 gallons to your YJ's gas tank in less than 1/2 hour?? - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Add 5 gallons to your YJ's gas tank in less than 1/2 hour??
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-30-2009, 12:24 PM   #91
nicehose
my only problem would be that 6 more gallons of weight would make my have a negetive 1 1/2 lift.......time for new leafs i know!!!
nicehose is offline   Reply With Quote Quick reply to this message
Unread 07-30-2009, 01:37 PM   #92
charred
looking forward to doing this, thanks alot!!!
charred is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 09:34 AM   #93
jesseleikerjeep
No kidding. I had never heard of this. I'm going to crack that son of a gun off on Saturday morning!!!
jesseleikerjeep is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 09:49 AM   #94
cubfanbudman
I've got a 3" body lift, I wonder if I can do this without removing the gas cap bezel, or whatever it's called. There's plenty of room in there thanks to a previous owner.
1995 YJ -TBI350/NV3500/231J RC 2.5
1996 ZJ Laredo-4.0 NP242
1996-ZJ-Orvis Edition
Doug
cubfanbudman is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 09:53 AM   #95
teampbr
I was able to get to mine by removing the plastic cover under the corner where the fill tube runs. I couldn't get a screwdriver in there to remove the hose clamps, but used a small 8mm wrench I believe. I have a stock suspension and had plenty of room.
teampbr is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 12:58 PM   #96
asbury
one of the first mods i done to my yj , as for the extra weight of the extra 5 gal of fuel just fill up the day before you go wheeling and by the time you getto your wheelin spot you have used most of that fuel so there should be no clearance problem
JEEP NAKED !!
asbury is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 01:05 PM   #97
Djsthe1
I did this MOD with ease without dropping the tank. Just pulled the plastic guard out of the way, took off the hose clamps and pulled the tube out with needle nose visegrips!
Djsthe1 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 01:30 PM   #98
dos0711
Same here. One of my favorite mods!
2000 Wrangler TJ, 4.0 6 cyl, A/T, G2 Dana 44s, ARB Lockers, 4.10 ratio
dos0711 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 03:49 PM   #99
MUDDYJEEP
Is this mod possible w/ 2.5l yj's (91+)? Pretty sure mine is a 12 gal tank and thought I read somewhere this mod doesn't work on the 2.5L (hopefully I didn't read that in this thread, lol)
MUDDYJEEP is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 07:54 PM   #100
hicketts
NO, it will work with the 2.5, I did it to mine 91+ were all poly tanks. It just depended on what neck insert they put in.
91 Wrangler 2.5 - 4" RE standard - 32/11.5/15 BFG All-Terains - 04 F350 Power stroke full Banks kit - 3" lift 35/13/16 Mickey Thompson MTX.
hicketts is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 09:23 PM   #101
YJake
I did it on my '91 2.5L and it worked. (19.something gallons)
I can now drive much further and have had no clearance issues due to extra weight even with flat stock springs.
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 11:39 PM   #102
Mr-Rock
Ok, after reading this thread I'm still confused on whether or not it will work on my 89. Are all poly tanks the 20 gal size? I have the ploy tank but I can only fit 15+ gallons in it.
'89, 4.2, NUTTERED, Team Rush, 4" lift, 1"BL, 1"MML, Flat belly skid, SYE, CV Driveshaft,
35 x 12.50s, XRC8, 150w KC's, Herculined, Tauras Elec Fan, Dual Batteries, 1" shackles & Soft Top for the summer, TJ flares.
Mr-Rock is offline   Reply With Quote Quick reply to this message
Unread 08-08-2009, 01:53 AM   #103
Azboy
Thanks Rock,
After reading through 7 pages, everyone seems to be ignoring us early YJ's. IF we can do it, what do we need to look for before taking everything loose only to find out it won't work.
Azboy is offline   Reply With Quote Quick reply to this message
Unread 08-11-2009, 11:18 PM   #104
hicketts
Originally Posted by Azboy View Post
Thanks Rock,
If you have the POLY tank, meaning plastic, not metal. Most of the pre-91 did not have the POLY tank's, they had the metal one's. The metal tanks were actually two different sized tanks, then when Chrysler started to phase out some of AMC stuff they went to cheaper to produce Plastic tank, and they all got one sized tank.
Unread 08-12-2009, 09:35 AM   #105
BitterOso
Junior Member
BitterOso's Avatar
I've done this mod on my 95 YJ (profile has all mods, nothing new since I increased tank capacity) without dropping my tank. I followed the instructions in the previous thread. The only thing I would add to the commentary here is, be careful when pulling the tube out of the tank. I ended up with a nasty cut on my wrist when my pliers slipped off the tube and my arm crashed into the edge of the tub (where the plastic gas cap housing was removed). I could easily have used 8-10 stitches. If I did it over again, I would have hung a towel around the exposed edges of the sheet metal at the tub.
I've been very happy with mod, though.
BitterOso is offline   Reply With Quote Quick reply to this message
