Add 5 gallons to your YJ's gas tank in less than 1/2 hour?? - Page 5 - JeepForum.com
post #61 of 165 Old 12-27-2008, 12:18 PM
TJineering
Ya this is true in both TJ's and YJ's. I did this to my tank in my TJ and got an extra 4 gallons out of it. Well worth the time!
Steve
Jeep - 99 TJ - 2002 4.0
TJineering is offline
post #62 of 165 Old 12-27-2008, 12:26 PM
Contra
i gotta do this...i really have been wanting more fuel in the tank...
you know what i was thinking, i have a 4 banger i think the tank holds 11.5 gallons, will this apply to me too?
Ever Gone Geocaching?
Contra is offline
post #63 of 165 Old 12-27-2008, 04:51 PM
HanksRide
Okay folks, 95 yj - I have this done, One problem, the vent tube that I removed is only approx 2.5" long. Either the mod has been done by PO or mine is not the same as the others mentioned. Either way I get approx 300 miles to the tank at approx 18 mpg = 16.66666 gallons of gas. What am I missing. That is when I fill it totally to the brim, running out on the ground. The most gas I have put in it was 15 to 16 gallons with it empty. I still have it apart if anyone has a quick answer. I don't think the mod had been done because the clamp that is so hard to get to was facing up. What person would have put it back in the same hard to get to position??
HanksRide
(Hank is Yellow Lab) He loves it!!
95yj 4.0L, 4" RC Lift, 8.8, Aussie Locker, Posi-Lok, Rock Sliders, 1" Booms, 33 X 12.50's, Rhino Lining, KC Day Lighters, Rock Bumpers, LED Dash Lights, XRC10 Winch
HanksRide is offline
post #64 of 165 Old 12-27-2008, 06:43 PM
Opihi59
from here it gets rough
Opihi59's Avatar
You can go to this site (Chrysler Customer Assistance) and request your build sheet. Of course you'll need to have your VIN available to type in , but they will get back to you via email within a few days, and the build sheet will tell you if your YJ came factory with the "20 gallon tank option." https://www.chryslerllc.com/en/chrysler_listens/
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #65 of 165 Old 12-27-2008, 07:54 PM
Contra
nice thanks
Contra is offline
post #66 of 165 Old 12-27-2008, 08:17 PM
JimZA
Is there anything in there that can break?
I alway fill up and put in about 13-14 gallons when empty. Out of the blue, last week I was filling the tank and when it reached 17 1/2 I stopped filling. I actually looked under the jeep to make sure it wasn't pouring out into the road or something. It buried the gas gauge past "F" and remained there for a few days. Seems to be dropping like normal now.
JimZA is offline
post #67 of 165 Old 12-27-2008, 08:26 PM
Contra
wow, possibly your reserve tank, just opened and is no longer seperate from your main tank
Contra is offline
post #68 of 165 Old 12-27-2008, 10:01 PM
carl6405
Ya know, I bought my 93 YJ just this past March. Apparently, this mod was already done. When I fill up, the guage goes way past full. On the flip side of that, just the other day, I was down to just above a quarter tank, according to my guage, but it took 19.5 gallons to fill it up. Just then I realized that the mod had been done, and to make and now I know where empty really is.
carl6405 is offline
post #69 of 165 Old 12-28-2008, 05:42 AM
Alacran
Reserve tank? That's a new one to me.
Alacran is offline
post #70 of 165 Old 12-30-2008, 09:41 PM
Zer0
a good word of advise for anyone who tries this; get a really good pair of pliers. It unbelievable how they wedge that inner tube in there.
Zer0 is offline
post #71 of 165 Old 12-30-2008, 10:27 PM
swedishdwarf
swedishdwarf's Avatar
True. Vise grips and WD-40 seemed to help.
You can't teach an old dogma new tricks.
swedishdwarf is offline
post #72 of 165 Old 12-31-2008, 09:50 AM
JaySpencer66
I had a 20 gallon tank on mine where I did a fuel filler re-location http://www.jeepforum.com/forum/f12/yj-fuel-filler-relocation-604160/ Not that you can see it in the shots that well, but getting to the clamps is not too bad if you pull the license plate and filler out. I was able to get my clamps off with a 1/4" wratchet and the correct socket.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
Member #1 of the "I Hate Torx Club!"
~anyone with a Jeep is an automatic member, and anyone can be member #1~
JaySpencer66 is offline
post #73 of 165 Old 03-07-2009, 07:16 PM
ghiradelli777
bring this back to life....i don't want to forget to try this mod on my day off!!!
i am going to request my build sheet in the meantime!
thanks for this guys!
1992 YJ Sport White 4.3 swap in progress
Eagle Scout Jeep Owner
ghiradelli777 is offline
post #74 of 165 Old 03-07-2009, 08:39 PM
Bojeepus
did this mod now i get aroun 300 to 325 miles a tank
Bojeepus is offline
post #75 of 165 Old 03-08-2009, 09:34 AM
ugmo
Did this mod on my first jeep about 6 yrs ago and did it when replacing the pump, so the tank was on the ground. I cut the tube down to 3" and got about 18.5 gal out of the mod.
I did the mod to my current jeep a few months ago and it was a pita without dropping the tank a couple of inches. Also, for some reason the tube seemed harder to get out, but I wedged a thin screwdriver between the tube and inlet to put a small bend in it and then pulled it out with needle-nose pliers. I just tossed the tube out and didn't worry about cutting it down. I went on a long trip a couple of weeks ago and coasted into a remote town while riding on fumes (had extra gas in back but did not need it ). Put 19.76 gals in the tank on that stop, so I'm thinking that tossing the tube is probably the best part of the mod.
ugmo is offline
Mediceagle
gas tank question..how many gallons? bcameron1974 YJ Wrangler Technical Forum 9 03-04-2009 10:20 AM
Gas tank is empty at 1/4? only 9 gallons?? njchuck YJ Wrangler Technical Forum 16 02-01-2009 11:44 AM
Getting More Gallons of gas in your stock tank? usmctadpole YJ Wrangler Technical Forum 4 01-13-2009 12:55 PM
19 Gallon Tank only fits 15 gallons Dudewayne TJ Wrangler Technical Forum 26 04-06-2006 09:18 AM
15 Gallons To 19 Gallon Tank Conversion- Easy CETROV YJ Wrangler Technical Forum 4 01-03-2003 04:41 AM
