accidentally put some gear oil into my gas tank - JeepForum.com
post #1 of 8 Old 03-31-2014, 12:54 PM Thread Starter
tkwok
I feel like such an idiot. I was trying to put some Lucas Fuel Treatment into my gas tank yesterday but picked up a bottle of 75W-90 gear oil from my garage instead since they were the same bottle size. I poured about 1-2 oz. into the gas tank before realizing I was using the wrong stuff. I had a full tank of gas at the time. I immediately got the right bottle Lucas Fuel Treatment and poured in the amount that I was supposed to use. I drove the Jeep for about 50 miles afterward and did not noticed any idling problems or engine problems. Will there be any long term damage to my Jeep as a result of my stupid mistake?
Should I change out my spark plugs after I use up this tank of gas? Should I change out anything else? (fuel injectors? fuel filter?)
thanks
tkwok is offline
post #2 of 8 Old 03-31-2014, 12:59 PM
jbolty
jbolty's Avatar
if it was just a couple ounces in 20 gallons of gas I wouldn't worry about it. I probably would not go in for a smog check until you burn a few tanks though.
jbolty is offline
post #3 of 8 Old 03-31-2014, 01:02 PM
TJ_Tim
Interwebz Specialists
TJ_Tim's Avatar
I wouldn't worry about it either... Run some cleaner through it on your next tank and call it done.
1969 Mercury Cougar 351w
1998 Jeep Wrangler Sport 4.0
2009 Yamaha V Star 950
2006 Jeep Commander 4.7 Base
TJ_Tim is offline
post #4 of 8 Old 03-31-2014, 01:08 PM
Que89YJ
I empty me 2 cycle into the rig after a couple months to keep it fresh. The worst thing you will do is make the cat work a little harder. You dont need to do anything.
Que89YJ is offline
post #5 of 8 Old 03-31-2014, 01:24 PM
jsawduste
2006 YJ Wrangler
1st mistake was thinking the Lucas was going to do anything but drain your wallet. 2nd was dumping a little gear oil.
Both are easily corrected.
Send me the money you blow on additives, I`ll take good care of it.
Other is to not give the gear oil/gasoline a second thought.
jsawduste is offline
post #6 of 8 Old 03-31-2014, 02:40 PM Thread Starter
tkwok
Good to know about Lucas fuel treatment being snake oil.
tkwok is offline
post #7 of 8 Old 03-31-2014, 02:58 PM
Rproject
1987 YJ Wrangler
jsawduste = subtle as a ban hammer
LOL
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #8 of 8 Old 03-31-2014, 06:19 PM
superj
That's an old school way of getting rid of mosquitoes, ha ha ha. Just playing, it won't hurt anything but if you put the whole bottle in, the smog police would have been chasing you down because it would have been smoking till that tank was used up
I don't feel like working on anything at this time so i sold my yj.
superj is offline
